tripod for Scamp 5th wheel - Fiberglass RV
Old 10-13-2012, 09:41 AM   #1
jrbowers07's Avatar
Name: Jim & Kathy
Trailer: Escape
Northern Colorado
Has anyone purchased a stabilizing tripod for a Scamp 5th wheel?
The goose neck on the Scamp requires a 2 inch ball.
jrbowers07 is offline   Reply With Quote
Old 10-15-2012, 02:18 PM   #2
Hey Jim, maybe ask these folks? Aluminum Gooseneck Stabilizer Tripod Horse Cargo Trailers - $128...
Old 10-16-2012, 09:06 AM   #3
jrbowers07's Avatar
Name: Jim & Kathy
Trailer: Escape
Northern Colorado
Thanks Donna,
The manufacture number 19-950400 is the Ulta-Fab part. I called Ultra-Fab and asked about a 2" ball. Because the top part is a single piece with ball and threads is aluminum, they did not think it was a good idea to weld a steel 2" ball onto this assembly. The issue is welding aluminum to steel, not strength. I have seen posts were people have do this though.
I have bought a BAL tripod with the gooseneck adapter. The adapter did not fit, so i drilled a 3/4" hole in it and mounted a 2" ball. We have not been out overnight with this yet, but it does stabilize the Scamp, and sets up like it should. A disadvantage is the unit is steel and heavier than the Ultra-Fab aluminum.
Jim
Old 10-16-2012, 09:32 AM   #4
Jim
My 2004 5er has the 3" lift. I use 2x12 pads and 6X6 blocks under the stablizers and landing gear and that really helps by not extending everything to the max.
Eddie
Old 10-16-2012, 09:44 AM   #5
Fran L's Avatar
Trailer: 2007 Scamp 16 ft
I agree with Eddie. We put a single large block of wood (about 15" tall and 15 inches wide and 7" deep) - scraps from a construction beam - under each landing gear foot so they don't have to extend very much. We have the telescoping BAL stabilizers welded unde the frame in the back. The Scamp stays real steady. But before we used the large blocks under the front landing gear it did get wiggly if the landing gear were significantly extended. We looked at the tripod but this solution was easier and cheaper. And the blocks aren't nearly as heavy as the cinder blocks we used to use!
Fran in NM
Fran L is offline   Reply With Quote
Old 10-16-2012, 09:58 AM   #6
Trailer: 13' U-Haul molded fiberglass
Louisiana
This is off your subject but can you please tell me how to post a new post? thanks!
1945gypsy is offline   Reply With Quote
Old 10-16-2012, 10:20 AM   #7
Roseanne, go to a main forum where you want to post: Problem Solving -- Owners Helping Owners - Fiberglass RV
Look for the "New Thread" button, I'm in default and it's up near the top of the listings.
scamp
MI: Scamp 5th Wheel Thomas G. Referrals: Molded Fiberglass Trailers 4 08-31-2012 11:41 AM
5th Wheel Scamp Dan Vang Referrals: Molded Fiberglass Trailers 0 04-29-2010 09:02 PM
Scamp 5th wheel You better just look at the ad Robin G Classified Archives 7 03-22-2009 09:44 PM
