Water Pump will not turn off - Fiberglass RV
Old 05-15-2024, 09:39 PM   #1
AmyFL's Avatar
Trailer: Casita Independence Deluxe 17
Hello - I am camping in the Keys. I have not used my 2019 Casita Independence for a couple of months. It is hooked up to water and electric at a state park. I flushed the toilet, and the water pump started making a loud vibrating noise. I filled the tank with more water, and tried running water from the sink and toilet to try to get air out. I turned the power to the trailer off and on. It is still on, still noisy and almost midnight. I am not sure how to fix it. I hope I don’t burn out the pump. Any advice? Thank you - Amy
2018 Casita Independence 17
2019 Dodge Ram 1500
AmyFL is offline   Reply With Quote
Old 05-16-2024, 03:30 AM   #2
C&G in FL's Avatar
Trailer: 2015 Escape 5.0TA
Assuming you can get online: YouTube: Adjust RV 12 volt water pump.
If you don’t have a leak, it should be a simple pressure shut off adjustment of a single screw. I would hope you have shut the pump off for now, a will only turn it on when you are ready to make the adjustment. On the other hand, it could be that the pump is not pulling water from the fresh water tank. That could be due to a clogged filter bowl on the tank side of the pump or an air leak. Also try YouTube for priming an RV 12 volt water pump.
What a long strange trip it’s been!
Old 05-16-2024, 04:53 AM   #3
Trailer: Casita Liberty Deluxe
LA
If you are connected to a water faucet (city water) you should have the pump switch in the off position.
If it's in the off position and still running you can either pull one wire off the back of the switch or pull the fuse out in the converter panel, you may have to pull a few to figure out which one it is.
daveandalice is online now   Reply With Quote
Old 05-16-2024, 07:07 AM   #4
AmyFL's Avatar
Smile Thank you Water Pump help
Hi - thank you for the responses. I went to sleep about 3:30 and it was off at 7. I ran water this morning and it is ok. I will look at the YouTube video as suggested and try to figure out where it is. It is not the switch inside to turn on, as that is for battery use. I am not mechanically savvy, but will try to look at it today - with power off.
Camping at Bahia Honda State Park. Very thankful the AC is working!
2019 Dodge Ram 1500
Old 05-16-2024, 04:19 PM   #5
Raspy's Avatar
Trailer: Reboot 19.4
Smith Valley, Nevada
Shut off the city water supply, open the faucet and see if water flows from the faucet with your pump running, or not. You may have just gotten some air in the pump and the city water prevented it from pumping. While using the city water, always shut the pump off.
Old 05-16-2024, 05:43 PM   #6
AmyFL's Avatar
City water
Hi - I am hooked up at the campground, and do not have the switch on for the pump. It shut off after about 5 hours. I will make sure to disconnect hose and try this if I have an issue going forward. Thank you!
2019 Dodge Ram 1500
Old 05-22-2024, 10:40 AM   #7
Trailer: Planning stage
The pump is usually a on demand style pump. May sound stupid but locate the pump have someone turn off the the power at the fuse panel. Pump should be off. Use a screwdriver to tap the top of the switch’s a few times. Sometimes trash can get caught somewhere in the switch system and the tapping will loosen it up. Could just be a bad pump ( I worked in marine industry) we replaced a lot under warranty. If you are hooked up the city water outlet no need for pump.flip breaker/switch off. If that doesn't turn it off, cut the red wire on pump where you can re-connect when replaced.
People think OH it’s only 12 volts, it’s not the voltage that hurts you it is the fire it causes.
Sammy Joe Quattry
4 Generations of Fishermen, 1 ROBALO
https://robaloboatowners.net/forums/
Sammy Joe is offline   Reply With Quote
Old 05-22-2024, 02:07 PM   #8
AmyFL's Avatar
Pump is ok now
After the pump ran for a few hours, it shut off. I camped seven nights and it was fine. Everyone is so knowledgeable. I need to work on my maintenance skills. Thanks again - Amy
2019 Dodge Ram 1500
Old 05-22-2024, 03:44 PM   #9
LarryB.'s Avatar
Trailer: SOLD: Casita17' Spirit Deluxe (aka: Tweaker's Casita)
Southwest Ohio
The water pump switch is a small nondescript unlabeled black rocker switch usually located at/near the kitchen sink in your Casita.
Note that the water pump is a 12v appliance so it is not related to the 120v shore power wiring but it will be on one of the small fuses located inside your power panel (converter box).
When connected to "city water" the pump acts as a backflow device to keep water from flowing into your fresh water tank. In this situation the "city water" connection provides the water pressure for the sinks, outside shower and the toilet. When not connected to "city water" you turn the pump on to deliver water from your fresh water tank to the sinks, outside shower and toilet.
LarryB. is offline   Reply With Quote
Why does my Cool Cat heat pump not turn on when it's below 45? lfkwtz Problem Solving | Owners Helping Owners 17 12-14-2020 07:22 AM
Exterior light won't turn off Sue and Henry Electrical | Charging, Systems, Solar and Generators 9 01-20-2013 07:16 PM
Java is a problem; turn it off now. Cam A General Chat 2 01-12-2013 04:13 AM
Log off or turn off? General Chat 0 01-01-1970 12:00 AM
