Water through the Boler spare tire bracket - Fiberglass RV
Old 05-18-2017, 06:46 PM   #1
Trailer: Boler 13' 1974
Should I be concerned about possible water entry through the spare tire mounting holes on the body of our Boler 13? I see no rubber grommets or such.
Butsky is offline   Reply With Quote
Old 05-23-2017, 01:23 PM   #2
bkboler's Avatar
Trailer: 1975 boler
Manitoba
Hi Ron, I had the same problem with my Boler. Not only did I have an issue when it rained but the inside had large washers which dripped water from condensation on cooler nights. I ended up taking the bracket off patched the holes and attached a spare tire mount to the back bumper. Easy choice for me because the boler still needs to be painted.
This is an old pic where I had put the mount at the front but I did move it to the back bumper. Looks nicer.
bkboler is offline   Reply With Quote
Old 05-23-2017, 09:37 PM   #3
Tire bracket leaks..
Just wondering if there originally was some kind of rubber grommet or seal on each body entry hole. With the original 43 year old 6.00 x13 tire that I just changed, the threaded rod was horizontal. With the modern 175/80R13 tire, being a tad larger, the rods are up higher at the tire side, leaving a small slope that might lead to water creep/flow down the threads and into the shell. Haven't had it in the rain yet, but was wondering what if!!
Old 05-23-2017, 10:14 PM   #4
Borrego Dave's Avatar
A little sealant at the body can't hurt............
boler
Can you show me how the spare tire is mounted on your Boler, or Trilli jenniferm Problem Solving | Owners Helping Owners 12 01-01-2015 12:30 PM
Crack "Through and Through" Hatchway Mr Jimmy Modifications, Alterations and Updates 13 01-10-2014 12:33 PM
Adding spare tire bracket to Boler? Stacy Crotser Modifications, Alterations and Updates 6 04-13-2013 12:52 PM
Spare Tire Bracket Pam Garlow Problem Solving | Owners Helping Owners 11 11-11-2010 11:16 AM
