What can I use to cover the walls/insulation inside my Burro's storage compartments? - Fiberglass RV
Old 07-05-2022, 08:45 PM   #1
Trailer: 1985 Burro
Maine
Hi, does anyone have any ideas for covering up the inside storage compartments on my 85 Burro? I'm keeping the insulation because I will be full-timing in it this winter, I just want to put something over it to clean up the small spaces. Maybe something that sticks on?
Open to all ideas! Thank you.
Kblue is offline   Reply With Quote
Old 07-06-2022, 07:21 AM   #2
If the insulation is foil bubble wrap, it works best when left exposed. It is meant as a radiant barrier to reflect heat back into the interior. It has negligible R-value as a thermal layer sandwiched between other materials. It also works well to cover windows at night.
If the insulation is something else, it would help to know what.
Your biggest challenge is going to be moisture control. What do you plan to use for heat?
Old 07-07-2022, 06:35 AM   #3
New Mexico
I used some of those foam interlocking floor mats cut to size for the walls and floor of the underbench storage compartments. Had some left over from doing the floor. Available at Home Depot. They really help to keep the floor warmer too.
Poodlesrule is offline   Reply With Quote
Old 07-07-2022, 07:59 AM   #4
Burrito's Avatar
Trailer: Perris Pacer
I second the interlocking foam. I got mine at harbor freight, used it on the entire floor area, including inside cupboards, then covered it with marine carpet. Helped noticeably with the drafts and feels good under foot.
Burrito is offline   Reply With Quote
Old 07-09-2022, 08:36 AM   #5
Trailer: 1985 Burro
Maine
I’m not sure what the insulation is I don’t think it’s foil bubble wrap because it has a layer of the pink fluffy insulation under the foil.
I’m going to have power hookup over the winter so plan to use an electric space heater.
Old 07-09-2022, 11:31 AM   #6
Trailer: 1999 Burro.
Smart Jacket in "Water Heater Support" thread.
I, literally, just did this in my '99 Widebody. I bought a "Smart Jacket" water heater blanket to wrap the heater and used the extra around the fridge vent and I removed the fiberglass on the fender well and still had enough of the "Smart Jacket" to completely cover the fender well and I still have a pretty good amount left over. I used actual "air duct tape" on the stock foil backed insulation everywhere it was torn or cut in the corner storage and under the countertop, around all the ports (city water) and what not. I also used "pool noodle" everywhere the glass was sagging... I pushed the noodles up into the "double wall part to pull up and hold the glass. I have been out on one trip since the pool noodles and they seem to be staying put. Anyway, between the tape and the Smart Jacket stuff there is no exposed glass and my water heater seems to work much better! I plan to use the Smart stuff to add "flap like" walls to the fridge to try and "optimize" its performance, I'll keep you posted. Hope this helps.
Mark in Tahoe is offline   Reply With Quote
Old 07-09-2022, 01:19 PM   #7
My other idea is corrugated plastic... I think you can get that stuff in any color and it is pretty easy to work with.
burro
Looking for U-Haul compartments for under the seats..... willwheelock Problem Solving | Owners Helping Owners 1 03-07-2019 12:45 PM
Good Reason Not to Have Outside Compartments Cyndi B. General Chat 10 05-07-2014 12:16 AM
Painting/Coating the inside of Burro compartments Thomas A Problem Solving | Owners Helping Owners 4 07-07-2013 08:58 AM
Success with Int paint walls,countertops,Cabinets, Carpet for floors. Walls, too? Gigi Problem Solving | Owners Helping Owners 2 08-31-2012 11:13 AM
compartments?they look terrible! Ryan Kennelly Problem Solving | Owners Helping Owners 18 03-24-2006 08:48 PM
