08-29-2020, 06:44 PM
Trailer: 1975 Ventura
Yukon
What is the best caulking?
I need to caulk around the top of my belly band. Ive read that silicone is not a good option. Any suggestions? Thanks, Sonny
08-29-2020, 07:02 PM
Why are you caulking the belly band?
08-29-2020, 07:36 PM
Yukon
I removed the band and filled the seam with flexible sealant. It was leaking bad. Now I'm putting the band back on and I want to seal along the top edge of it. Just to be sure.
08-29-2020, 07:58 PM
Got it. So, you're talking the metal band, not the vinyl insert.
Have a read of this thread on the Escape forum. Discusses caulks and uses.
https://www.escapeforum.org/forums/f...nce-16903.html
08-30-2020, 10:47 AM
Yukon
Thanks appreciate it
08-30-2020, 10:55 AM
Trailer: Bigfoot 25RQ
Geocel Proflex RV
08-30-2020, 01:24 PM
Trailer: "Egg Camper"
520-220-7552
If you want a permanent seal that will resist UV, use "3M - #5200" marine caulk.
08-30-2020, 03:43 PM
Lexel is good.
11-17-2020, 06:25 AM
Trailer: ford
mexico
I used Dicor 501LSW Self-Leveling Lap Sealant. This stuff is great for sealing your RV's roof seams and penetrations. It sticks like crazy and flows into all the nooks and crannies. Beware: If you get it on yourself you have to mechanically remove it, if you get it on your clothes, you'll never get it off. Get plenty: I used 1-2 tubes per roof vent and 2-3 per full-width seam, so a full dozen was just the right amount for a 31' RV's three roof vents, two sanitary vents, two seams, and other various roof penetrations. Don't bother with silicone or any other sealant - they won't stick to your roof and they will leak in a couple of months. You can consult!
https://vogeltalksrving.com/best-rv-caulks/#more-1819
11-17-2020, 10:40 AM
Trailer: LiL Hauley
Syracuse, NY
I have used Geocell ProFlex RV with good success. I wet a small piece of paper towel with mineral spirits. You apply a small bead about 3-4 feet long then wet my finger from the paper towel with mineral spirits and lightly work it with my finger. Looks great when finished. You can get in different colors and clear. I sealed my belly band with the black stuff.
Good video:
I have used lLexel but it seems to skim over instantly and does not work well. It's good for sealing in areas that won't be seen.
Dicor is also good stuff.
Only use 3M 5200 if you don't want to take something apart latter. Use 3m 4200 for that. Watch some utube videos.
11-17-2020, 12:02 PM
Trailer: Happier Camper
Utah
Caulk
I have to agree .... use marine caulk, which was recommended to me by the manufacturer. Also from what I understand, it is more flexible, which is probably better suited to the movement.
07-31-2022, 08:38 PM
Trailer: ford
mexico
Used this caulk from Dicor to install a couple of fantastic vents on our camper. The stuff that came off the old vents looked like it was this and some other kind of tough caulk. The tough stuff was almost impossible to remove from the rubber roof. One tube was enough to sufficiently install and seal the vent holes for two new units. We did a seam around the bottom of the fan lip before installing, around the lip, and cover the screw holes of the new units.
08-11-2022, 08:19 PM
Trailer: ford
mexico
This RV caulk doesn’t have any discoloration over time. I notice that a lot of sealants have this weird shade of yellow over time. This one seems to be able to blend with the color of the material it’s on. That said, it’ll be easier to sell your RV in the future because this sealant can help make it look brand new at the very least.
08-12-2022, 12:12 PM
Trailer: Casita SD
