I run a dehumidifier in my
Casita SD for most of our rainy season. I also keep it heated in our wet winters. I agree with Mr. Lynn and Jon in AZ-pull out bedding, blankets, etc, open the cabinets. Can you cover the camper to prevent any more leakage? Can you run heat to it, to help dry it out?
You need: a dehumidifier, some fans, a source of heat, like an oil heater. Put them all to work.
If you didn't have mildew in the camper before this unfortunate incident, you might not have to worry, but I would be very proactive in drying that puppy out as much as you can.
I would also either photograph or map where the
leaks occurred. You think you will remember, but by spring, you'll probably have forgotten just where the wet spots were. If you document it, you'll know where to check for mold.
And when weather permits, even in the winter, I'd repair the busted rivet and caulking as soon as possible.
And shut the vent.
Casitas bust rivets just sitting there, I swear, we've replaced half a dozen over the years at stress points. I honestly believe
Casita uses rivets as a time saver-one person can rivet whereas a stainless steel bolt needs two people, one inside and one outside to install. When you find an acorn nut on the floor, you know it's how Casita alerts you to yet another busted rivet.
It sounds, as Jon pointed out, that you caught it quickly, and fast action will save your bacon.
Don't beat yourself up too badly about leaving your Casita uncovered.
If it makes you feel any better, I was hosing out the toilet a few years ago. I'd been too lazy to find a spray gun, I just pinched the hose to control the water flow. Stupid me, I put the running hose down INSIDE the camper to go out and shut off the water.
You probably heard me shrieking at my stupidity. It hadn't been running for more than a minute, but still...
But I got much of it sopped up, used a wet dry vacuum to get into the cabinets, used up a LOT of Dri-Z-Air (beware, the resulting liquid is toxic to a degree, but it IS effective) put in a few fans and ran the dehumidifier for a week.
It worked. No mold, no mildew, and a much chastened me now makes SURE I shut off the darned hose and always use a spray gun.
Good luck. It'll be okay.
