Window Channel Part/Weep Holes. - Fiberglass RV
Old 06-04-2018, 08:53 AM   #1
Trailer: Burro
Morning All!
We made a creative fix to our front window (1980 Burro), conducted a leak test yesterday and found our creative fix was a fail.
We ultimately need to replace the window slide channel that goes on top and bottom of the sliding windows (check out the photo).
While I'm on the topic of windows has anyone attempted to drill additional weep holes in their windows?
While we haven't had rain here in Tucson, AZ in 96 days, I want to get this fixed before our monsoon storms start up this month.
Thanks!
- Ashley
wxmixte is offline   Reply With Quote
Old 06-04-2018, 10:26 AM   #2
A few Uhaul owners have drilled additional weep holes. Note that the hole also has to go through the channel liner. Another idea that seems to help is shoe laces run through the weep holes and hanging out some, to help wick out the water. Have not tried it myself, but others have reported it did help.
Old 06-04-2018, 01:35 PM   #3
If they are the slider windows, like on Scamps, the rear window, in particular gathers a lot of dirt while traveling. Then when it rains, or you wash the rig, the mud clogs the weep holes (slots) and the water gets inside.
So, periodic cleaning with a wire is necessary. If possible, wait until it is real dry, and blow it out with dry air as you poke with the wire,
Also, as they age, the sealing rubber around the glass shrinks and leaves a gap where water can get in. Caulk those with silicone.
Old 06-04-2018, 03:15 PM   #4
Trailer: 13 ft Scamp
Might also try cleaning the hole w/ string from a weed eater
Old 06-04-2018, 04:16 PM   #5
Trailer: Scamp 13 ft
Weed eater ?
Make sure the Weed Eater is turned off ! ! !
DavidG is offline   Reply With Quote
Old 06-04-2018, 08:29 PM   #6
I take a drill bit that's a little smaller diameter than the weep hole, and using my fingers to hold the drill bit, spin it while working it up into the hole. This tends to pull the dirt down and out through the hole and away from the window rather than pushing the dirt back up into the channel where it might or might not actually clean out the opening. Or that's my working theory, anyway....
Screw holes. How do I repair the old screw holes around the Window. BeckyK Care and Feeding of Molded Fiberglass Trailers 5 07-17-2017 07:03 PM
Functioning Weep Holes honda03842 Modifications, Alterations and Updates 1 08-28-2014 10:23 AM
Leaking Burro front window & weep holes Colleen Rae Problem Solving | Owners Helping Owners 2 05-21-2014 06:35 PM
Need rear sliding window channel with flocking - need exact part number idiotsniff Problem Solving | Owners Helping Owners 16 06-27-2013 08:45 PM
Fiber Stream Window Weep Hole Covers Frederick L. Simson Problem Solving | Owners Helping Owners 0 10-09-2007 10:27 PM
