Window seal not sitting right... - Fiberglass RV
Old 06-26-2018, 10:09 PM   #1
Trailer: 1974 Boler
hello everybody!
i have a bit of a concern as i have just replaced the windows and seals and used the one piece seal. no matter what i do, a small gap of about 1-2 mm between the boler and seal persists! Its really annoying and i have tried tapping it in every which way to move it...im not sure what i could be doing wrong... any help or advice would be amazing!
CoCo Diablo is offline   Reply With Quote
Old 06-27-2018, 05:16 AM   #2
John in Michigan's Avatar
Trailer: 1979 Boler 1700
Corey, from your pics I can't tell which windows you replaced. If you replaced the front and rear plexiglass windows, a two part seal is used (one part of the seal wedged into the other part of the seal).
Old 06-27-2018, 05:24 AM   #3
Corey, here is a thread dealing with the front window seal. The portion of the seal that inserts into the other seal is referred to as the lockstrip.
http://www.fiberglassrv.com/forums/f...ips-71340.html
Old 06-27-2018, 07:48 AM   #4
Trailer: 1969 Boler 13'
Hard to tell from the pics but....the seal has one narrow and one wide "slot" for the shell and plexi....is it possible the seal is in the wrong way?
If you got the seal from a glass shop it comes in different "slot" sizes too...
Al
Gippeto is offline   Reply With Quote
Old 06-27-2018, 07:54 AM   #5
John, some of the seals have an attached lockstrip, so they're referred to as one-piece. Principle is the same.
Al, I was thinking along similar lines. If the slot on the shell is a too narrow, that might cause the flange to splay out a little.
Hopefully a Boler expert will be along to confirm the correct specs for the seal.
Old 06-27-2018, 11:54 AM   #6
Trailer: 1974 Boler
thanks for the replies! ya it is a one piece seal...all i can get in canada. It is installed correctly, and i did read a few articles before hand just to make sure i wasn't missing a step. Its a straight forward process. But for some reason i can seam to get it to sit properly. i also made sure the new window was the same thickness before plopping it in. below is a pic of the seal i used. as you can tell there is only one way to put it in.
Old 06-27-2018, 12:17 PM   #7
Is the lockstrip / bead on the inside or outside? (Can't tell form the photo)
If it is on the inside then see this post from our resident Boler expert:
http://www.fiberglassrv.com/forums/f...tml#post545355
Old 06-27-2018, 12:22 PM   #8
Where did you get it? Local glass shop had the two piece seal in stock...$3/ft with the locking strip.
If you can, might be an idea to run it down to a glass shop...get a pros opinion....
Al
Old 06-27-2018, 12:58 PM   #9
Trailer: 1974 Boler
Lock strip is on the out side, and I picked up the seal from argus industries as per the thread regarding window replacements...
right trailer, right tow veh. mike daeumer Problem Solving | Owners Helping Owners 10 10-02-2016 04:45 PM
1985 Burro 17' seems to be sitting too low shumiron Towing, Hitching, Axles and Running Gear 9 10-28-2011 01:55 PM
Window Gasket, Window Seal, Window Molding D Shubel Problem Solving | Owners Helping Owners 9 05-16-2011 04:30 PM
Sitting in my bathroom at home Legacy Posts General Chat 5 08-22-2003 12:52 PM
Sitting in my bathroom at home Modifications, Alterations and Updates 0 01-01-1970 12:00 AM
