Wiring an xantrex sw 2000 w - Fiberglass RV
Old 06-03-2012, 01:11 PM   #1
Trailer: forest river stealth
I just bought an xantrex prowatt sw 2000. I already have a generator installed with a transfer switch, I need a diagram in order to connect my power inverter to the breaker box in the RV. So if I don't have the generator running or shore power connected, I want a be able to use my laptop or watch TV WITHOUT going outside and manually connect my inverter. My inverter comes with a in-line transfer switch.
Thank you
Mike
remarkablemen is offline   Reply With Quote
Old 06-03-2012, 03:27 PM   #2
Thomas G.'s Avatar
Do you have this?
http://www.xantrex.com/documents/Accessories/PROwatt-Transfer-Switch/975-0588-01-01_Rev-A(Auto%20Transfer%20Switch).pdf
Old 06-03-2012, 03:55 PM   #3
This is what I did with two ATS 301. http://www.parallaxpower.com/ATS/ATS...20BULLETIN.pdf
My system is fully automatic. You could do the same with just DPDT switches.
George.
GeorgeR is offline   Reply With Quote
Old 06-03-2012, 04:30 PM   #4
Raz
Raz's Avatar
I am curious what batteries you are using for such a large inverter? Raz
Old 06-03-2012, 04:51 PM   #5
I actually have two 6 volt batteries on the rv. Tom yes I have that transfer relay and the xantrex remote panel I wanna make sure it will work properly once install...
Old 06-03-2012, 04:53 PM   #6
George what's a DPDT switch for ??
Old 06-03-2012, 05:11 PM   #7
Thomas G.'s Avatar
Originally Posted by remarkablemen View Post
........Tom yes I have that transfer relay and the xantrex remote panel I wanna make sure it will work properly once install...
The reason I included the link is that it has installation instructions.
Old 06-03-2012, 05:50 PM   #8
Automatic transfer relay has DPDT connection (Dual Pole - line and ground; Dual Throw - on/on). You could use DPST. ATS benefit is elimination of mixing power inputs even accidental. A few months after wiring there is a possibility of forgetting so built safety logic, such ATS is safer.
I would opt for either fully manual plug in cable or system with built in safety to prevent power inputs mix which would not be good.
George.
Old 04-19-2016, 09:38 PM   #9
Trailer: KZ Sportman 355TH
Inverter transfer switch wiring
Did you install a 120 volt primary to 24 volt secondary transformer for the DPST and STSP switch. This will eliminate the 120 volt conductor to the main box. 24 volt would be less obtrusive to route from the front of RV to main breaker box and provide a lower voltage for safety
Ricky
RVYerena is offline   Reply With Quote
Using Xantrex Battery Monitor kevin61 Problem Solving | Owners Helping Owners 0 07-13-2008 02:42 PM
SOLD? 2000 17' Caista 2000 - Craigslist Robin G Classified Archives 1 06-16-2008 04:02 PM
Xantrex power pack with solar panel Daniel V. Modifications, Alterations and Updates 9 03-05-2008 09:26 AM
Xantrex 600 Hd Rarebird Electrical | Charging, Systems, Solar and Generators 3 07-13-2007 02:00 PM
