Wiring new marker lights - Fiberglass RV
Old 08-25-2020, 03:36 PM   #1
BraddyMac's Avatar
Trailer: 1981 Trillium 5500
Hi All I have used the search engine and can't seem to find an answer to my question. I have to replace some marker lights that were poorly installed on my 5500 Trillium. The ones I removed were wired with two wires, and the only ones I can find for replacement only have one wire. How do I make the proper connection?
BraddyMac is offline   Reply With Quote
Old 08-25-2020, 04:11 PM   #2
John in Michigan's Avatar
Trailer: 1979 Boler 1700
If the marker light has only one wire, that's the positive lead. The negative or ground connection is via the attachment screws or studs.
Old 08-26-2020, 10:13 AM   #3
I solder a white ground wire to the lead that goes to the screw mounting. You could also add a ground wire with a ring connector and install it under your mounting screw. But with these fixtures soldering in the ground is the way to go. They now sell the miniature grommet mounted running lights, they have two leads.
Eddie
Old 08-26-2020, 11:14 AM   #4
Trailer: 2013 Escape 19
Or just buy the right light with two wires. Amazon, eBay, etc. LED for the win.
light, lights
Tail lights, marker lights, reflectors jeroen Modifications, Alterations and Updates 15 10-30-2017 06:06 PM
Trillium Original tail lights/marker lights to LED Cassie Trill Modifications, Alterations and Updates 13 07-23-2016 09:04 AM
Installing new trillium side marker lights Stevedamnloud Problem Solving | Owners Helping Owners 2 06-17-2014 01:55 PM
Brake Lights, Turn signal lights, marker lights, oh my! glamourpets Problem Solving | Owners Helping Owners 19 01-03-2013 10:10 AM
Side marker lights Maggie O. Problem Solving | Owners Helping Owners 10 06-12-2006 03:18 PM
