Wiring questions for 1974 Trillium 1300 - Fiberglass RV
Old 04-28-2021, 01:01 PM   #1
Trailer: Trillium
Saskatchewan
I am having trouble finding the Trillium Wiring diagram on this sight. I have a 1974 Trillium 1300, and I need an idea of how the tow vehicle sends power to the trailer for the interior 12 volt lights, and 12 volt fridge, and so on. It looks like the guy who had it before me disconnected it all. I have tried to find it in the documents section but I can't .
Leif Sperling is offline   Reply With Quote
Old 04-28-2021, 02:16 PM   #2
David Tilston's Avatar
Take a look at this one:
https://www.fiberglassrv.com/forums/...m%20wiring.pdf
Old 04-28-2021, 03:13 PM   #3
Trailer: Trillium
Saskatchewan
Thank you! this makes sense. So these old ones don't have a power converter hey?
Old 04-28-2021, 03:18 PM   #4
A converter was not available till the later models. The manuals for the converter are also available:
https://www.fiberglassrv.com/forums/...rConverter.pdf
Old 04-28-2021, 03:24 PM   #5
Trailer: Trillium
Saskatchewan
Sorry I have one more question. Is the big square on there a power converter? I know the others are recepticles.
Old 04-28-2021, 04:11 PM   #6
Trailer: 2013 Escape 19
Early ones interior lights were 120v AC. Power center was an option. If you have a power center it will be listed on the paper inside the closet door.
Old 04-29-2021, 10:19 AM   #7
Trailer: Trillium
Saskatchewan
I am sorry. I mean on the wiring diagram.... is the big square on there the power converter? looks like both 110 and 12 volt go in and out of it on this diagram.
Old 04-29-2021, 10:54 AM   #8
I would assume that is the converter. No label though.
It should be noted that this is NOT a battery charger. If you try to use it to charge your battery, you will soon need a new battery. It has no voltage control and it will boil your battery dry.
Old 04-29-2021, 03:01 PM   #9
The wiring diagram on the document center includes optional items. Your trailer could have less. Either your trailer had a power center or it didn't. Diagram reflects what originally was possible, depending on how equipped your trailer was. Example in my case, wiring drawing shows a battery and a 7 pin connector. Mine had neither.
Old 04-30-2021, 07:57 PM   #10
JanelleNorthernBC's Avatar
Trailer: Trillium
Originally Posted by David Tilston View Post
It says page not found for both documents. Is there another way to view them? We will be doing wiring soon as well
JanelleNorthernBC is offline   Reply With Quote
Old 05-01-2021, 06:49 AM   #11
John in Michigan's Avatar
Trailer: 1979 Boler 1700
Trillium 1300 wiring diagram
Found this wiring diagram for the Trillium 1300:
https://www.fiberglassrv.com/forums/...do=file&id=134
Old 05-01-2021, 07:08 AM   #12
comments on the Trillium 1300 wiring diagram
This diagram is consistent with the original factory wiring I found in my Trillium 4500 including the wire colors. Features:
- Large box is a rudimentary ac-dc converter tied to 110 vac 15 amp shore power. Note only 1 ac circuit and 1 dc circuit, each protected by a button circuit breaker. Also as mentioned earlier the ac-dc converter is not designed to charge a battery.
- No battery in the diagram. My 4500 had a battery patched in to the towing cable on the tongue (black and white wires).
- 40 year old Dometic fridge is wired to run either 110 vac OR 12 vdc OR propane. There is NO 12 vdc power connection or draw when switched to propane mode.
EDIT NOTE: 40 year old Dometic fridge 12 vdc mode consumes 10 amps, thus only practical when using the tow vehicle power plug. This is an ammonia absorption fridge.
Old 05-01-2021, 07:17 AM   #13
progressive dynamics converter data sheet
Here is the data sheet for the rudimentary PD converters originally installed in Trilliums:
https://www.progressivedyn.com/wp-co...4/pd69xx-2.pdf
Old 05-03-2021, 08:52 AM   #14
Well, It worked the day I posted it. I probably should have linked to the page that has those links. I think others have done that.
Old 05-03-2021, 12:30 PM   #15
Actually, there is a battery on the diagram:
Name:	Trillium Electrical2.jpg
trillium
Wiring diagram 1976 Trillium 1300 rjgodbout Towing, Hitching, Axles and Running Gear 11 09-10-2019 06:30 PM
For Sale: 1974 Trillium 1300 1300 Mooncusser NEW Fiberglass RV Classifieds | Buy, Sell, Trade 0 05-23-2019 01:37 AM
questions, questions, questions cathybr Problem Solving | Owners Helping Owners 4 06-22-2017 10:47 PM
Trillium 1300 wiring diagram needed. William Neufeld Problem Solving | Owners Helping Owners 1 07-08-2008 12:07 PM
