13' scamp dinette modification measurement ? - Fiberglass RV
Old 11-27-2016, 06:44 PM   #1
Trailer: In the market
We just purchased a 1978 13' Scamp and would like to modify the front bunk/bench into a small dinette.
Does anyone have the measurements of the front dinette (individual booth and table size) produced for the 13' Scamp Deluxe?
Scamp factory does not sell those and suggested building in wood.
Any advice would be much appreciated!
Bernie in MN is offline   Reply With Quote
Old 11-27-2016, 08:26 PM   #2
Is your trailer a Deluxe?
If not you can simply modify the fiberglass bench to make a dinette...
Old 11-28-2016, 08:04 AM   #3
There are two basic approaches.
One is to use the existing bench and the porta-potty recess as the footwell. This is the simplest and allows you to retain the upper bunk if desired. Basically you cut the fiberglass around the footwell, box it in for support, cut a table to fit, and mount it on a pedestal or attach it to the front wall.
The other is to remove the bunk, fill in the recess to create a level floor and build new benches up from there. It's a lot more work, but it allows you to have a larger table, to sit higher for a better view out the front window, and to offset the table toward the door side for easier access to the galley-side seat. That how Scamp does it on the deluxe models. They also add a storage closet on the galley side against the wall, since that seat is deeper.
Old 11-28-2016, 12:58 PM   #4
I noticed that your Scamp is a1978.(no Deluxe back then) The first picture in my earlier post is a 1978 Scamp13 which I built. the A/C is built-in in the front so the table is stationary .
OH!...I forgot to say that the conversion with the wood frame in my first post was done by another member , but I thought it was a great example.
Old 11-28-2016, 07:37 PM   #5
Floyd, much thanks for your info. We are gathering pix and details for work to be done in the summer. I'll post the final results in the summer. Bernie
Old 11-28-2016, 07:39 PM   #6
Jon, your pix and ideas regarding the bench transformation into a mini-dinette were really helpful. This will be a project to be started in the spring/summer so we are gathering info! Best, Bernie
Scamp Measurement needed SallyBEE Problem Solving | Owners Helping Owners 4 07-27-2015 07:12 AM
Seat to countertop measurement.... DaMScampers Modifications, Alterations and Updates 14 03-10-2015 03:53 PM
Surfside interior installation measurement help Cthomas Problem Solving | Owners Helping Owners 0 07-03-2014 08:25 PM
Need a measurement Kevin K Problem Solving | Owners Helping Owners 5 02-28-2012 06:18 PM
In need of a measurement..... Shane O Problem Solving | Owners Helping Owners 2 07-11-2010 07:13 PM
