1986 Boler Upgraded - Page 10 - Fiberglass RV
Old 11-10-2022, 10:01 PM   #181
Markz's Avatar
The box itself is aluminum, which absorbs heat quickly. I have to do some more testing but I hypothesize my solution should work long term.
The tray sits slightly higher, about 2 inches, than the lowest exhaust bend. I am concerned that excess condensation in the pipe will eventually choke out the exhaust. Accordingly, I just picked up an exhaust drain to splice into the line. Hopefully, this solution will prevent my concern from becoming a reality, so I can focus on turning the tray into a large muffler/heat trap. Attachment 147879
Markz is offline   Reply With Quote
Old 11-11-2022, 07:22 AM   #182
Trailer: Scamp 13 D
Massachusetts
Black soft feeling closed cell pipe insulation will help, (not the crispy feeling open cell type) It bends easily& won't absorb road water...you might need another wrap of the fiberglass 1st as you'll be close to its heat tolerance. I still need to put some on my set-up as the fiberglass doesn't have too much R value...
ACHINBAC is offline   Reply With Quote
Old 11-11-2022, 07:21 PM   #183
Markz's Avatar
Great idea.
Old 11-12-2022, 09:24 AM   #184
Trailer: Northwood Nash 22/1977 Trillium 4500
Beautiful work!
Originally Posted by Markz View Post
We had a chance to make a few upgrades before heading out for the family vacation. New cabinet doors, back splash, porthole, Corian counter, induction stove, under-mounted original Boler sink, instant hot and cold running water, on demand 12v water pump, led lighting, bunk beds, microwave, electric heater, and shelves to name a few.
Hope you like it.
In the near future I will be mounting a Propex LP2000 heater under the couch for winter boondocking.
Wow it looks like you did a lot of useful improvements!
Shangie is offline   Reply With Quote
Old 11-12-2022, 09:29 AM   #185
Copying your microwave door idea! Thank You!
Hope you like it.
I love how you divided the closet doors and created a mini table for the microwave- we are copying that. Excellent! Thanks!
Old 11-14-2022, 05:55 PM   #186
Markz's Avatar
Thanks
Old 11-20-2022, 10:05 PM   #187
Markz's Avatar
Tested out the winter modifications in a windy 19 degrees Fahrenheit day. Using only the Propex heater, after 4 hours, I was able to get it warmed up to 48 degrees.
I find it still a little too cold so planning on the following upgrades:
1. install insulation inside corner cubbies top and bottom, as well as in the closet,
2. Making some reflectix window covers,
I also found out my propex heater exhausts condensation found its way into the propane box, making everything wet. Apparently, the hot water vapor is able to up travel through the floor vents.
Back to the drawing board:
Will install a thick aluminum tube to run exhaust through to work as a heat sink and capture as much heat as possible while directing the water vapor elsewhere. I am using exhaust gases to warm up my LiPo batter and LP boxs.
I must say, I am impressed by the Propex hs2200 performance. It's battery usage is quite negligible.
Will report on the winter upgrade's performance when it's all installed.
I did also notice that the interior furniture and appliances were retaining a lot of the cold. I'm sure. given a few more hours, those surfaces would have warmed up considerably.
Old 11-26-2022, 02:45 PM   #188
Markz's Avatar
Finally got to reworking the Propex hs2200 exhaust.
I purchased a 30mm aluminum tube to create a path for the hot exhaust to travel below the tongue box while serving as a heat sink to transfer radiant heat to the bottom of the tongue box.
By extending the gasses to the front of the tongue box and creating a bit of a shield to redirect the gasses away from my front most floor vent, I can now feel the radiant heat warming the tongue box floor without any of the moisture getting into the box.
Attachment 147974Attachment 147975
Old 11-30-2022, 09:57 AM   #189
Markz's Avatar
I took a tip from ACHINBAC's pictures and purchased some exhaust vent covers to keep the critters out of the Propex inlet and exhaust. Will post when installed. Click image for larger version
Old 12-11-2022, 11:24 AM   #190
Markz's Avatar
I picked up a Kelty Backroads Shelter to assist with winter camping, giving us a place to remove wet shoes before entering the Boler. As it is snowing today, it was a perfect day for a first try. I love how easy it is to set up alone and how compact it gets, easily stowing under the bench.
Attachment 148052Attachment 148053Attachment 148054Attachment 148055
Old 12-11-2022, 03:38 PM   #191
Markz's Avatar
Did a bit of insulating today.
Added some adhesive backed 1/4" insulation to the inside storage areas.
I assume this addition will help keep things comfortable. Attachment 148056Attachment 148057Click image for larger version
ID:	148060Click image for larger version
ID:	148059Click image for larger version
Old 12-12-2022, 09:57 PM   #192
Markz's Avatar
Finishing up on the insulating:
Just completed the Reflectix window covers.
I purchased some upholstery edge piping and a large role of Velco tape (hooks only).
We cut the reflectix to overlap the windows and sewed the piping to the edges to protect them and add a bit of finishing. We then adhered the Velco to the inside edges.
Quite pleased with the end product and looking forward to trying them out. Click image for larger version
ID:	148066Click image for larger version
ID:	148067Click image for larger version
Old 12-13-2022, 06:53 AM   #193
Markz's Avatar
Window coverings attached:Attachment 148071Click image for larger version
Old 12-13-2022, 10:03 PM   #194
Markz's Avatar
Just finished the rest of the windows. Click image for larger version
Old 12-24-2022, 07:33 PM   #195
Trailer: Scamp 13 D
Massachusetts
Hey Mark! Wishing you & Xin a very Merry Christmas fromJackie & I (posted it here as have had trouble w/pm in the past)
Old 12-27-2022, 12:18 PM   #196
Markz's Avatar
Just spent a very cold morning cutting and fitting 3/8" thick foam interlocking mats to the camper floor in hopes of further insulating our Boler.
It's not a scientific test, but kneeling on the mats is considerably warmer than kneeling on the composite flooring directly.
I believe it will help winter camping be a bit more comfortable and can remove when things warm up. Click image for larger version
Old 12-28-2022, 07:22 PM   #197
julmar's Avatar
Trailer: 2018 Escape 19
Alabama
I believe it will help winter camping be a bit more comfortable and can remove when things warm up. Attachment 148125
You are the Johnny Hung of bolers! He’s the mod guru of escapes.
julmar is offline   Reply With Quote
Old 12-30-2022, 05:24 PM   #198
Markz's Avatar
Thank you!
Old 12-30-2022, 05:37 PM   #199
Markz's Avatar
Just got back from our first winter night of camping. It was 28 degrees Fahrenheit, so below freezing but not by much.
All the new winterizing work has paid off.
The interior of the boler stayed a comfortable 66 degrees with little effort. Actually kept the thermostat at the mid-point between cold and hot the entire night.
Looking forward to colder nights on future trips out.
Before the sun went away. My son and I were blessed to have family stop by for an impromptu BBQ.
We had planned for it to feel cold all night; long underwear, extra layers... definitely overkill for what we experienced inside our camper last night. Click image for larger version
ID:	148142Click image for larger version
ID:	148143Click image for larger version
ID:	148144Click image for larger version
ID:	148145Click image for larger version
ID:	148146Click image for larger version
ID:	148147Click image for larger version
Old 01-08-2023, 08:55 AM   #200
Trailer: Scamp 13 D
Massachusetts
Congrats on your sucessful maiden winter trip!
Looks like a great time Mark! Attached are pics of a product that would help you deploy and anchor your Backroads Shelter to the Boler - a Keder Rail w/ associated "roped" fabric which you would stitch to the underside of the shelter at some point back from the upper edge of the top flap - you'd determine the location by locating where to mount the rail 1st.
boler
3 inch lift, upgraded axle & 15 inch rims on Scamp 16 foot BrewskiDV Modifications, Alterations and Updates 12 05-01-2016 11:21 PM
Upgraded to a Nova Kool R3000 ajdemo76 Modifications, Alterations and Updates 0 05-30-2015 07:05 PM
MB | Upgraded 10' 1973 Bugeye Boler $5,900 Grantz Classified Archives 1 06-06-2013 08:34 PM
Copyright ©2000 - 2023, vBulletin Solutions Inc.
