1986 Boler Upgraded - Page 5 - Fiberglass RV
Old 06-06-2021, 10:31 PM   #81
Markz's Avatar
Time to get the luggage [emoji3466]
Originally Posted by Markz View Post
Rack is almost done! Attachment 141340
Markz is offline   Reply With Quote
Old 06-07-2021, 08:20 AM   #82
FRED SMAILES's Avatar
Trailer: 13 ft Boler
Just breezed through the thread.
Full of great ideas, installs and results!
You are very talented!
Fred
I'd rather do it myself, done right or not. Isn't that what a hobby is all about?
https://www.fiberglassrv.com/forums/...ler-55601.html
FRED SMAILES is offline   Reply With Quote
Old 06-08-2021, 07:05 PM   #83
Markz's Avatar
Thank you Fred
Old 06-08-2021, 07:15 PM   #84
Markz's Avatar
Working on the Propex heater now.
More pics to follow. This shows the exhaust installed.
Old 06-11-2021, 07:36 PM   #85
Markz's Avatar
Finishing up on the rear rack/baggage thingy. Click image for larger version
ID:	141442Click image for larger version
Old 06-11-2021, 07:41 PM   #86
Markz's Avatar
And another! Click image for larger version
Old 06-11-2021, 08:10 PM   #87
Fredomatic's Avatar
Trailer: 1974 Perris Valley Pacer
And another! Attachment 141444
Love the rack on the back! Good to see you having fun with it all. 😎
Fredomatic is offline   Reply With Quote
Old 06-11-2021, 08:55 PM   #88
Markz's Avatar
Thanks, there is still more to but I see some light [emoji92] at the end of the tunnel.
Old 06-12-2021, 03:21 PM   #89
Jay H's Avatar
Trailer: Boler 1300
Okay, that back suitcase is awesome. Love the personality it gives the trailer.
Gotta ask though, what are the 5 "buttons" on the suitcase - between the straps? Reflectors, lights or a backup camera?
Jay H is offline   Reply With Quote
Old 06-13-2021, 08:59 PM   #90
Markz's Avatar
The five "buttons" are break/turn signal lights, reverse lights and a back up camera.
Old 06-13-2021, 09:34 PM   #91
Markz's Avatar
Now that things are finally coming together the refrigerator died and my hot water heater is cracked. I noticed an interesting sound of water flowing as I approached the camper after turning the hose on to test it. I have been planning on replacing the fiber-board composite floor for several years with a vinyl flooring substitute. Once my floors swell up from the gallons of water poured on it, I will have the perfect excuse to start that project. I left the air conditioner on high, I hope it will dry things out by the morning. I tilted the trailer back and drilled a drain hole. Ugh!!
On the bright side, the camper floor, below my composite flooring, is fiberglass. I don't have to worry about rot
With all the COVID renovations our camper was sitting outside more often. I forgot to winterize it; water must have froze in the lines. Maybe the cold is what killed the refrigerator too.
I'm now looking for a Dometic RM 2200 refrigerator replacement and I have to order a replacement water heater. Mine was 6 years old. At least they still make it...
Going camping regardless
Old 06-15-2021, 05:34 PM   #92
Markz's Avatar
We are loving it!Click image for larger version
Old 06-18-2021, 04:20 PM   #93
BC
How are you liking your induction stove, would you recommend the True Induction brand. I'm completely rebuilding a 19' Scamp fifth wheel (completely gutted at the moment and thinking to add an induction cook top as part of this reno. Thoughts?
Vanisle is offline   Reply With Quote
Old 06-20-2021, 04:29 PM   #94
Markz's Avatar
We love it, but I must say it was a bit of a science experiment. If you only plan to camp "hook-upped," then going electric will be a pleasure. However, if boondocking is an interest to you then going propane is potentially better unless you are willing to make additional modifications.
In our current situation I wanted both the convenience of induction cooking and the ability to boondock, while still using the induction stove.
The answer was to design and build a big enough battery bank/solar generator capable of running the electric appliances while being space and weight conscience.
Old 06-25-2021, 11:44 PM   #95
Markz's Avatar
Two weeks in Acadia National Park went so well. Our camper was a welcome sight at the end of each day.
Now to continue with upgrades...Click image for larger version
ID:	141710Click image for larger version
ID:	141711Click image for larger version
ID:	141712Click image for larger version
Old 06-27-2021, 11:44 PM   #96
Markz's Avatar
Acadia!Click image for larger version
Old 08-15-2021, 08:48 AM   #97
Markz's Avatar
Finished installing a new inverter and upgrading our master control center. :-)Click image for larger version
Attachment 142722
Old 08-15-2021, 09:14 AM   #98
Markz's Avatar
Since I forgot to winterize last winter, my water heater burst, oops [emoji51]. Finally got the chance to replace it with a newer model. 4Click image for larger version
ID:	142718Click image for larger version
Old 08-15-2021, 07:42 PM   #99
Markz's Avatar
Finished installing the Propex heater, belly band lighting and updated the porch light. Click image for larger version
ID:	142743Click image for larger version
ID:	142744Click image for larger version
ID:	142745Click image for larger version
ID:	142746Click image for larger version
ID:	142747Click image for larger version
Old 08-16-2021, 07:31 PM   #100
Markz's Avatar
My wife was less than impressed with our internet reception on our last outing. I solved that!!
I mounted the receiver and output antenna under the sink. The input antenna is mounted on a PVC pipe that can be broken down.
Attachment 142770Attachment 142771Attachment 142772Attachment 142773
boler
3 inch lift, upgraded axle & 15 inch rims on Scamp 16 foot BrewskiDV Modifications, Alterations and Updates 12 05-01-2016 11:21 PM
Upgraded to a Nova Kool R3000 ajdemo76 Modifications, Alterations and Updates 0 05-30-2015 07:05 PM
MB | Upgraded 10' 1973 Bugeye Boler $5,900 Grantz Classified Archives 1 06-06-2013 08:34 PM
