1986 Boler Upgraded - Page 6 - Fiberglass RV
Old 08-17-2021, 02:44 PM   #101
Trailer: Trillium 1980 1300 Deluxe
Massachusetts
very nice!
jbclabaugh is offline   Reply With Quote
Old 08-17-2021, 04:22 PM   #102
Markz's Avatar
Better pics of cell phone/internet booster. Click image for larger version
ID:	142779Click image for larger version
ID:	142778Click image for larger version
ID:	142780Click image for larger version
Markz is offline   Reply With Quote
Old 08-20-2021, 03:38 PM   #103
Markz's Avatar
All clean and ready for a trip out Click image for larger version
Attachment 142822
Old 08-27-2021, 05:39 PM   #104
Markz's Avatar
Just got back from another amazing trip! Our Boler performed flawlessly. Click image for larger version
ID:	142907Click image for larger version
Old 08-27-2021, 05:50 PM   #105
Markz's Avatar
Just got to use the new "Driver Control Center." Worked great. Click image for larger version
Old 08-27-2021, 08:35 PM   #106
Trailer: Parkliner 2018
Maryland
1984 Boler 13' Re-Makeover
Holy Moses MarkZ! I've never seen anything so impressive. The time and skill PLUS patience has left me gobsmacked. How much time has this taken you? Wow. Just simply: WOW!
Maria in MD is offline   Reply With Quote
Old 08-28-2021, 05:28 PM   #107
Markz's Avatar
About 12 years and counting. Thank you.
Old 08-28-2021, 05:36 PM   #108
Markz's Avatar
I will be revisiting the "control panel" soon as I am now looking to add another 3 in one switch to the 6 gang plate. The new switches will activate: the water pump, belly band light and cell phone booster.
Pictured here is the master control panel as it presently sits. Click image for larger version
From left to right:
Top row:
Epever solar controller panel;
Propex heater controller;
Inverter controller; and
Lithium batteries monitor.
Bottom row:
120v outlet with USB;
Hot water heater switch;
Outside 120v outlet switch;
12v outlets;
12v Switch lights (to be replaced with three switches); and
Three 12v outlets switches (front, upper and lower rear)
Old 08-28-2021, 06:10 PM   #109
Markz's Avatar
I will also be switching out the old blue switch box with a new type of modular 6 gang box and new screwless switch plate. Click image for larger version
ID:	142924Click image for larger version
Old 09-02-2021, 08:51 AM   #110
Trailer: ECO 13'
Your Boler is outstanding! Well thought out and well done! Love that your door actually fits, love the added shelving, everything electrical, the suitcase, well, everything! Thanks for sharing & for inspiring me to do more!
Susan in Flagstaff is offline   Reply With Quote
Old 09-02-2021, 03:24 PM   #111
Markz's Avatar
Thank you, I love that you find it inspiring.
Old 09-02-2021, 03:50 PM   #112
Markz's Avatar
This is when we started it all.
Some links to other parts of this project: (Newest to Oldest)
How our Solar Boler electrical was re-imagined and built
Thread on working through Solar issues
Our first thread - how modifications began with video link
Old 09-02-2021, 04:27 PM   #113
Markz's Avatar
Originally Posted by basicfish View Post
you have done a beautiful job on your Boler, I will borrow several of your ideas for my Compact Jr.
could you post more info about the kitchen vent fans? It is a super clean install, I want to copy how you built it.
thanks
Ron
I included some detailed pictures of the vent build in a video I made a while ago.
Click this Link:
Old 09-02-2021, 06:48 PM   #114
Markz's Avatar
I had some time to think about how I was going to move around the camper using its own power.
My first concern was getting it raised and lowered. Solved that by adding an electric tongue jack. Click image for larger version
Old 09-02-2021, 06:51 PM   #115
Markz's Avatar
My next concern: How to drive my boler around the driveway without a vehicle...
ID:	142973Click image for larger version
ID:	142974Click image for larger version
Maybe someday I'll be able to post a video.
Old 09-05-2021, 06:20 PM   #116
Markz's Avatar
Here are pictures showing the new trailer coupler we welded and bolted to the frame. As far as couplers go, this one has made our towing so much nicer. It solved the bang and racket I would hear when towing with the OEM coupler, while giving be a way to security lock it up while Parked. Very pleased.Click image for larger version
ID:	143053Click image for larger version
Old 05-11-2022, 06:48 AM   #117
Markz's Avatar
Camping Season Begins!!!Click image for larger version
Old 05-24-2022, 07:35 AM   #118
Markz's Avatar
Belly band:
I created a jig to bend the 3/4" Home Depot channel. Bent four peices to wrap around the camper and pop rivited every inch or so. All It takes is time, patience and beer.
The jig is made by tracing out the curve of the body onto a peice of MDF, which is them sandwiched between two 2x4s. I used the cut out peice of MDF to squeeze the C-Channel into the jig using large C-clamps. Attachment 146025Click image for larger version
ID:	146026Click image for larger version
ID:	146027Click image for larger version
Old 06-06-2022, 09:41 PM   #119
Markz's Avatar
Next project is upcoming.
Will be replacing 5000btu air conditioner with 6000btu unit and a softstart kit.
Old 06-24-2022, 09:45 PM   #120
Markz's Avatar
Turns out that the next project was to repair our Dometic RM211 Refrigerator whose heating element had burned out.
Happy to report its up and running; so well I can use it as an ice box if desired.
Unable to find an OEM replacement, I was able to locate a heating element which is similar to the original used in my Dometic.
I used an Astral/Frigiking 38-00426 Heating Element which runs 140w-110/12v with a 5/8" diameter tube.
It posed some difficulty in that the fridge was designed for a slightly smaller heating element. To make room for the larger diameter unit, I used a grinder to slice open the cover and cut the sleeve that retained the original element length-wise. This allowed me to pry open the sleeve and widen it for the larger heating element to fit. I wired it up; re-stuffed the fiberglass insulation; and patched up the sheet metal.
Works better than new.
The original heating element is rated at 95w and this new element is rated at 140w. For now I am limiting the thermostat to 75% power.
ID:	146363Click image for larger version
ID:	146365Click image for larger version
ID:	146366Click image for larger version
ID:	146367Click image for larger version
boler
3 inch lift, upgraded axle & 15 inch rims on Scamp 16 foot BrewskiDV Modifications, Alterations and Updates 12 05-01-2016 11:21 PM
Upgraded to a Nova Kool R3000 ajdemo76 Modifications, Alterations and Updates 0 05-30-2015 07:05 PM
MB | Upgraded 10' 1973 Bugeye Boler $5,900 Grantz Classified Archives 1 06-06-2013 08:34 PM
