A/C Mod on a new Casita - Fiberglass RV
Old 07-23-2021, 06:40 AM   #1
Shocksll's Avatar
NC
I just picked up a 2021 Casita and if you haven't heard, they are having supply chain issues with the A/Cs. I got a Mach 3+ but instead of my thermostat controlling the temperature, I have the knobs in the ceiling. Since I also have a furnace, I have a fully functional thermostat that could control the heat strip in addition to the gas furnace. I've been reading through the instructions for this A/C Mode that Greg Zimmerman put together here: A/C Mod (thermostat for the A/C) – The Handy Camper
Has anyone done the mod on a newer Casita?
These instructions were for using a home thermostat vs the RV thermostat that I have. It mentions adding a switch for the furnace, but given I have a newer thermostat that supports a gas furnace and heat strip, I feel like I shouldn't need that added switch. I have a good understanding of electronics but haven't ever done anything with A/C units or thermostats.
So my thermostat is the Airxcel 9630A337 which seems to have the following wiring:
Red +12 VDC
Blue -12 VDC
Gray Fan Lo
Green Fan Hi
Yellow Compressor
Wht/Blk Heat Pump
White Furnace
So the original instructions talk about adding a jumper between White and Yellow, but since White runs my furnace, I am thinking I should jumper between Yellow and White/Black. And then connect either of the Yellow or White/Black terminals to the 12 VDC pole of the relay (since I don't have a Rh or Rc). Does anyone know if this seem correct?
If I understand this correctly, that will enable me to set the thermostat to cool, set the knobs to hi/low cool and the thermostat will cut power to the A/C when the set temperature is reached. Then if I set the thermostat to heat strip, I set the knobs to heat and the thermostat will cut power to the a/c (heat strip) when the set temperature is reached. Then if I set the thermostat to gas furnace, it will function just like it does currently from the factory.
Any thoughts from those that know more about this than I do? Thanks!
222712034_10161687575748312_7438675555201899984_n.jpg   223949933_10161687575883312_5815585129379824851_n.jpg
Shocksll is online now   Reply With Quote
Old 08-04-2021, 06:22 PM   #2
Shocksll's Avatar
NC
Fyi, I was able to get this worked out better than expected. Here’s a video of what I ended up doing: https://youtu.be/0dBaBN1fkoU
Old 08-14-2021, 07:04 AM   #3
Trailer: Currently Shopping for fiberglasses
Thanks for sharing the video! I'm getting close to ordering a 2022 Casita - maybe (hopefully?) some of these supply chain issues will have settled out by the time I end up getting mine.
TashH is offline   Reply With Quote
Old 08-14-2021, 07:31 AM   #4
Trailer: shopping
Tx
Red +12 VDC
Blue -12 VDC
Gray Fan Lo
Green Fan Hi
Yellow Compressor
Wht/Blk Heat Pump
White Furnace
We are supposed to pick ours up in Feb of next year. I hope they have this issue figured out as this could be a no go for us.
jeepers29 is offline   Reply With Quote
Old 08-16-2021, 01:23 PM   #5
Shocksll's Avatar
NC
Yes, hopefully both of you won't have to deal with that by next year. Who knows though.
Old 08-17-2021, 07:40 AM   #6
I did this A/C T-stat mod many years ago, (2008,) to my Coleman Mach Polar Cub A/C unit. I also included a toggle switch next to the T-stat to revert the T-stat to control heating as opposed to just A/C. I can control my A/C from the T-stat, or I can switch it over for heating control. I can further select whether I want to use it for temperature control using just the propane furnace, or the electric heating element inside the A/C unit, or both simultaneously.
Old 08-17-2021, 01:51 PM   #7
Trailer: Casita 16 ft
Remote control for AC
My remote control for the Casita AC: 3' long wood dowel 3/8" dia. I" sqiare wood block with a 1/4" wide by 3/8" deep slot on top, 3/8" hole 3/8" deep in bottom.
Force the dowel into the hole along with wood glue. Reach up with it and turn thermostat. Stores neatly on top of seat cushion next to bed.
Friz is offline   Reply With Quote
Old 08-17-2021, 02:31 PM   #8
Trailer: Trillium 1980 1300 Deluxe
Massachusetts
old school works.
jbclabaugh is offline   Reply With Quote
Old 09-10-2021, 09:26 AM   #9
Interesting, we just took delivery of a 2021 Casita Liberty Deluxe and got the Mach 3 Plus A/C with black interior shroud and it is wired into the single thermostat that controls the furnace also. Or at least I think it controls the furnace, haven't tested that yet :P
christsay is offline   Reply With Quote
Old 09-10-2021, 02:17 PM   #10
Trailer: Scamp 19
Enchanted Mountains of Western New York State on the Amish Trail in Cattaraugus County!
We are already in the new norm, only to get worse!
parmm is offline   Reply With Quote
casita
Casita SD Side Dinette Mod Joe Z Modifications, Alterations and Updates 14 09-18-2018 06:00 PM
big MOD's of our 1981 Scamp "Mod Pod" CAROLPHAYES Modifications, Alterations and Updates 26 06-11-2014 09:38 AM
Casita- LCD TV/AIO PC Mod Aids10 Modifications, Alterations and Updates 5 03-25-2012 01:01 AM
SOLD-17' 2003 Casita Liberty Dlx with twin mod or King Bed Chuck-H Classified Archives 10 02-08-2008 09:25 PM
Interior 17 LD Casita Mod Patt Weaver Modifications, Alterations and Updates 6 04-05-2006 04:58 PM
