adding second set of tail lights to 2014 16' - Fiberglass RV
Old 08-28-2024, 02:53 PM   #1
beardrum's Avatar
Trailer: Scamp 16 Deluxe
Hi All,
I know 've seen this topic before, but dang if I can find it....
I'd like to add another set of tail lights to the back of my rig. I see tail light assemblies are available from Scamp. I'd probably use two "passeger side" lights, mounted just above the belly band.
I'm wondering if you all think the tail light circuits (running light, stop light and turn) are big enough to handle the extra bulbs?
I plan on fishing the wiring under the rat fur. It should be easy enough to glue back in place, right?
Should I put in some sort of plywood backing on the inside, or do you think the layer of fiberglass would be enough to hold the lights in place?
Thanks for any advice or words of wisdom.
Chuck
Chuck
2015 16' Deluxe Scamp, Layout "B"
2013 Highlander
beardrum is offline   Reply With Quote
Old 08-28-2024, 04:58 PM   #2
another option is a marker / turn / stop light bar above the rear window. Available in LED so little load.
Old 09-05-2024, 11:02 AM   #3
AC0GV's Avatar
Wisconsin
Originally Posted by beardrum View Post
Hi All,
Chuck
I added a reading light to my small bunk and ran the wires under the insulation next to the fiberglass using stiff wire (a hanger). I did not pull the headliner off the wall, just poked the wire under the liner and Astro-foil.
Old 09-11-2024, 10:58 AM   #4
Trailer: scamp
Indiana
Not sure what you would get over a single good set. Now upgrading to LED would help a lot. The original incondesent ones are not very bright in real use. I switched and got comments on how bright the were.
Have wanted the blink a couple times then on I see on some vehicles for brake lights. But not sure how to get that.
computerspook is offline   Reply With Quote
Old 09-11-2024, 11:34 AM   #5
There’s a problem with the height on older Scamps. They’re so low that they can’t be seen easily by a large truck or other higher vehicle, especially in close traffic. I like the idea of upgrading the OEMs to brighter LEDs and adding a high-mount brake light over the rear window. Plus one if it has the initial strobe feature of some newer units.
Too much distracted driving out there!
Old 09-11-2024, 11:53 AM   #6
AC0GV's Avatar
Wisconsin
Flashing brake light
The older Scamp brake lights were very low. If you were following in a big truck the high brake likes are MUCH more visible than the low ones.
https://kahtec.com/
Old 09-11-2024, 12:20 PM   #7
Trailer: scamp
Indiana
Well I like the idea of the light above the rear window better than me side ones. Probably running the wiring would be "fun" either way. If the trucks having trouble seeing your rear light he's probably too close. But yeah too many of them do that.
Old 09-11-2024, 12:40 PM   #8
Too close for normal traffic, yes, but when you're in a rolling backup, it's a different situation.
Old 09-12-2024, 01:58 PM   #9
FL
I added a two 12volt led strip lights and wired it to my existing tail light ..one on running light and one brake/ turn single. Wicked brighter low dough no drilling upgrade. Two years working.
mosquito13 is offline   Reply With Quote
eco, light, lights, scamp, tail lights
adding trailer tail lights JT33 Towing, Hitching, Axles and Running Gear 13 03-01-2018 07:27 AM
Original 1974 Boler tail lights set Barb & Bob MacD Classified Archives 3 09-30-2016 09:39 AM
Adding second battery to Bigfoot Chris Z Electrical | Charging, Systems, Solar and Generators 2 06-29-2016 12:23 PM
Adding second battery breid19 Electrical | Charging, Systems, Solar and Generators 19 07-24-2009 10:09 AM
LED lights in Original light sockets - tail lights Cam A Modifications, Alterations and Updates 75 02-15-2009 11:54 PM
