I have several items connected to a 12 V distribution panel for direct DC connect. As the DP is on the front of the camper and most of our "living" is towards the dining area, it is a bit more complicated than just a DC hookup. My wife does not share my enthusiasm for such add-ons, and she is not technical at all. So, using the KISS principle, I decided that this puts the USB in a common area, no extra wires, and not complicated in the install, and easy for her to use. (If the wife ain't happy....!)
My amateur radios use a supplemental
battery mounted near the HW heater, charged via
solar or mains power. As my radio draws 20A, it has to be a low ohm-age connection, so the main problem is access and a heavy cable. I was going to add USB and power out for the radio in the same area, but it would necessitate making holes in the main cabin for a connector plate, and I don't want to do that. The combined AC/USB plug addressed one problem, my small LIFE
battery + a roll up cable answers another. That cable will be direct to the radio, so it becomes "Wires I can see!!" to her, so radio time is limited to my solo camping.
So, allow me to back up and punt....."If you have a sig other who hates extra wires and such as much as my wife, then this may be a solution."
How Dat?
Derswede
