Back up camera on Scamp - Page 2 - Fiberglass RV
Old 07-26-2022, 02:14 PM   #21
Trailer: 2005 Scamp 19' 5th Wheel
We chose to add a backup camera to our 19' Scamp that is hardwired to the monitor in the rear-view mirror. It is mounted against the trailer just above the spare tire. We also have a camera focused on the bed of the truck, wired to the same monitor. There is a power button in the dashboard and a switch in the glove box (to switch between cameras). He wiring harness is a four-prong that runs along with the Scamp harness and plugs in next to it under the bumper of the truck.
I like being able to check the bed of the truck while traveling to check the load (both the hitch and anything else we have tied down back there) and to use the backup camera as an auxiliary rearview. Caveat: backup cameras visually distort as do passenger-side rearview mirrors. Objects in the camera are WAY CLOSER than they appear (which also means that you won't see that Maserati coming up your $#s until it's too late), but it nonetheless offers another piece of information when passing and merging.
Ottoscamp is offline   Reply With Quote
Old 08-03-2022, 08:22 PM   #22
DougOlson's Avatar
Trailer: Escape
In our Scamp 16 I had installed a Garmin camera that syncs to the gps on the dash. Camera mounted inside rear window and the wireless transmitter mounted inside the front wall on the Scamp, in a closet and I cut a small hole in the reflectix to help the signal. As long as I did not fill the back of the pickup with metal objects blocking the path it worked fine.
DougOlson is offline   Reply With Quote
Video Back-up camera. Which one? David & Terry Problem Solving | Owners Helping Owners 6 02-28-2017 06:46 PM
VR3 wireless back up camera John Perry General Chat 2 02-11-2017 10:20 PM
$29.99 back up camera Perry J General Chat 14 02-05-2013 01:29 PM
Back-up Camera on a FGRV Sandra L Care and Feeding of Molded Fiberglass Trailers 27 11-24-2009 09:38 PM
Back-up Camera on a FGRV Sandra L Towing, Hitching, Axles and Running Gear 0 01-01-1970 12:00 AM
» Trailer Showcase
Biggerfidg
kirkman
Scamp
Gilda
Copyright ©2000 - 2023, vBulletin Solutions Inc.
