Beachcomber B-15 - Page 2 - Fiberglass RV
Old 08-15-2020, 09:59 PM   #21
Trailer: Beachcomber
Saskatchewan
Your rebuild is looking awesome. I am just about to seal all my cracks in the roof of my beachcomber. Do you think that product would seal all the cracks or should I be doing the fiberglass repair first and then sealing it will this product? I fixed my sag almost exactly how you did yours.
Ward929 is offline   Reply With Quote
Old 08-16-2020, 08:04 AM   #22
Trailer: 1970 Barth continental 24'
Saskatchewan
Looks good. What measurements were you looking for.
Stooky is offline   Reply With Quote
Old 08-22-2020, 07:00 PM   #23
Trailer: 77 Beachcomber
Hilton Beach
curious about paint used
The Beachcomber is looking great! What brand/type of paint did you use for the grass green and rv white?
The Cac is offline   Reply With Quote
Old 08-24-2020, 12:10 PM   #24
Saskatchewan
Its will fix small cracks in the gel coat, but if the cracks are in the fiberglass i would do a full repair
Joshua is offline   Reply With Quote
Old 08-24-2020, 12:13 PM   #25
Saskatchewan
the paint i used was cloverdale armour shield
Old 08-24-2020, 12:15 PM   #26
Saskatchewan
the paint i used
Cloverdale Armour Shield
Old 08-24-2020, 12:19 PM   #27
Saskatchewan
paint i used
Old 09-19-2020, 10:39 AM   #28
Saskatchewan
Originally Posted by Alysia View Post
Hey! My husband and I just got a beachcomber too over the weekend and payed soooooo much more than you. We paid $4500. Just discovered all the water damage the day after we got it so now we are gutting it and starting from scratch. We are in SK too.
Hi from another SK person (Saskatoon). We just picked one up last week and gutting it!
rydroid is offline   Reply With Quote
Old 11-21-2020, 11:04 PM   #29
Wilsonville
Hi Joshua,
Really appreciate all the detail and photos!
I am renovating a ‘79 beachcomber TM - gutted it.
1) How did you measure for the door supports? I need to replace mine and how did you attach them?
2) How did you attach the new 2x2 side “supports”
3) How did you measure for the ceiling supports and how did you attach them?
4)The floor inside right around my door is sagging - worn out fiberglass. Did you have this problem? How would you fix it?
Thanks!! So appreciate your info!
Teresa in Orego.
Teresa in Oregon is offline   Reply With Quote
Old 11-22-2020, 02:45 PM   #30
Hilton Beach
Answer re: Door Supports
I can help with the door support details.
In the latter years of production of the BC, the company made a design change to address door frame distortion. They began reinforcing both sides of the opening with a wrought iron brace. I have attached the original drawing of the braces with dimensions as well as an arrangement of the door frame area. Of course the brace need not be made of iron but could be wood or laminated ply.
I hope this helps you.
Old 02-11-2021, 10:10 AM   #31
Hilton Beach
Painting questions
Hi Joshua, you earlier gave me a lead on the paint you used and i have found a local source in Ontario. I do have a few questions if you dont mind.
Did you prime or base coat with anything before applying the ArmourShield? If so what product and how many coats?
How many coats of Armour Shield did you apply? How much product did you end up buying?
Did you paint the roof with the same product? Underside?
Did you clearcoat over the Armour Shield?
Is the Armour Shield thick requiring thinning in order to spray? If so, what did you thin with?
Thanks in advance.
Mark
Old 07-20-2021, 11:16 PM   #32
Trailer: 1976 Beachcomber B15
Sk
Great work. I have a 1976 b15 that I have gutted and re-doing. What did you use for replacing door seals and fibreglass front and rear window?
Rchap is offline   Reply With Quote
beachcomber
1978 beachcomber b15 cathielee Problem Solving | Owners Helping Owners 9 08-09-2017 02:01 PM
Beachcomber? Roy in TO Care and Feeding of Molded Fiberglass Trailers 5 04-09-2006 11:11 PM
Beachcomber 1979 T15 Legacy Posts General Chat 1 08-10-2003 10:07 AM
Beachcomber and Surfsider General Chat 0 01-01-1970 12:00 AM
1979 Beachcomber 15 ft. General Chat 0 01-01-1970 12:00 AM
