Bed extension in 13’ scamp - Fiberglass RV
Old 06-04-2020, 01:15 PM   #1
Chuck n Julie's Avatar
Trailer: 2001 Scamp 16 ft Side Dinette
We started off years ago with a 16 scamp. We later downsized to a 13 foot. Very happy with the 13 as it is really easy to deal with pulling, etc. Problem is both campers had the same bed. I am tall 6’ 2” my wife is 5’ 6” and the bed is just not big enough. Also don’t like changing the bed into a table, big hassle. So I came up with a bed extension that literally take less the one minute to set up and same time to take down and nothing to remove from the camper. I removed the table and used 3/4 marine ply piece for the bed and extension. Sanded nice and triple coated the wood for smoothness. Added aluminum channel for the slide out extension that comes close to the bottom table with a bit so it does not bind. The extension pulls out with ease. Also the extension is the same length as the table 45” and can pull out as far as 45” but 24” is enough. Leaving 20” still in channel for much support. The cushion we use extends the bed 24” and the width is 36” between the heater/fridge side to the other cabinet side. I made the cushion from the top bunk bed, to get the material the same. Also the cushion has a 24x36 plywood in it that was from the same bunk bed ply inside. The plywood spans the extra little space next to the cabinet where there is no slide out under. The legs are pontoon table supports that go on and off like quick. These are the surfit (ITC) that you can remove the cap on either end by placing the end in boiling water then they come off, to cut the legs the proper length, then replace and glue cap back on. Then a extra memory foam covered top to makeup the extra space and feel of the memory foam on the bed (pictured in white covered). We can quickly extend the bed more then the 24” by just adding a small rolled up blanket between. Now the bed is really big for me and my wife. Are legs go on the extension. You can crawl over the extension to get out if needed and will hold any weight. Now I am going to make a front dinette with lots of room to get in. When the extension is out 24” you can still Open the fridge and have moving around room to cook etc.
F790B0BE-583C-4412-A760-7220EF358D0B.jpg   B7238F88-535A-41D5-A18A-7881066732DD.jpg
18352C56-A64F-4387-9F0A-938B93E7538B.jpg   5BCB6BEC-FB8D-4637-8391-E667BECA944B.jpg
Chuck n Julie is offline   Reply With Quote
Old 06-04-2020, 07:20 PM   #2
Jon in AZ's Avatar
Very nicely done! Have you, or will you, do the front dinette modification to have an eating spot?
Old 06-04-2020, 07:47 PM   #3
Yes, that is next project. Trying to decide if keep the bench or remove it and start from scratch
Old 06-05-2020, 09:53 AM   #4
North Dakota
Looks great! Please post the results of your next project, too.
Linda M R is offline   Reply With Quote
Old 06-05-2020, 04:30 PM   #5
Trailer: 1992 Scamp 13'
Would love to see you make a dinette with existing bench as that is what I hope to do at some point in my 13' Scamp.
Either way, I look forward to your solution.
The bed extension looks great!
1992 Scamp 13' Standard, 2017 Casita 17' ID,
2008 Scamp 16' Deluxe Layout 4
lisantica is offline   Reply With Quote
Old 09-26-2021, 07:20 AM   #6
Trailer: Scamp 13' Shopping
Thumbs up 13' BED MOD - WOW
Thank you so much for posting your 13' bed mod. So pragmatic and do-able the way you approached it.
Please update (with pictures - please your dinette project. We have a 13' on order (searched for years for a used 13' without bathroom) and are already thinking of how to make some of the adjustments you have.
Hommy Joy is offline   Reply With Quote
Old 09-26-2021, 08:27 AM   #7
Trailer: 13 ft Scamp
Very clever bed extension
I’d also like to see pic of dinette
scamp
17' Bigfoot rear bed extension AlexK Modifications, Alterations and Updates 4 02-18-2020 11:28 PM
Big bed extension board question Gompka Problem Solving | Owners Helping Owners 3 06-14-2018 06:46 AM
Scamp 19 upper deck extension Eddie Longest Modifications, Alterations and Updates 7 12-28-2011 09:02 PM
Rear bed extension brenjean Problem Solving | Owners Helping Owners 1 07-27-2007 05:23 PM
Bed extension for 13' Scamp Cindy and Kent G. Problem Solving | Owners Helping Owners 2 08-08-2006 06:43 PM
