Since these fans would only work when running A/C, how about when the
fridge was using
propane? Would I need to insert a switch, then remember to turn it on? hahaha If these fans are designed for 110V does the trailer converter automatically change that to 12V when using the onboard
battery?
I have trailed before, a 12" Bobbie by Taylor Coach near Hamilton, ON. I drew it with a 100hp TDI VeeDub. I always switched it to
battery when driving, so the car
battery would run the fridge. The image is from the bottom of the Copper Canyon in Mexico circa Dec. 2007.
I'm also butyl taping some fly screen on the back of the louvers. I noticed a ton of dead critters at the bottom which could compromise the
weight and subsequent fuel economy.
I had a local sheet metal shop make an aluminum frame, slightly larger than the original Dometic 12 x 22. I'll affix this to the
fiberglass with some #10 x 3/4" stainless steel screws. All exterior fixtures will be either SS or aluminum rivets.
I suppose I should begin a new thread with my own NS reno/remodel. This is as far as I've got right now. The veg garden took precedent then we had the 9-day atmospheric river and it looks like we are in for 'nother. The climate is very unstable...
