Bracing a bunk to side of Scamp - Fiberglass RV
Old 08-07-2020, 02:44 PM   #1
Trailer: Uhaul
Any structural concerns in bracing a bunk to the side of the scamp? The red in the image represents the framing of my bunk that's braced to a (green) strip of wood. I'll have another brace on the other side of the window. SS bolt with washers to even the load and the wood strip itself also spreads the load. This is to prevent the bunk from falling over laterally. Most of the load is vertical being managed by the red framing. Thoughts?
foofght is offline   Reply With Quote
Old 08-07-2020, 04:33 PM   #2
Trailer: Uhaul
I'm wondering if I can just pull back some of the rat fur and insolate and just glue on the strip of wood with a strong adhesive? That's a bit more permanent, but it seems like there'd be less risk of a bolt causing damage on the outside hull. Thoughts?
Old 08-08-2020, 09:48 AM   #3
Virginia
I think I would try to figure out what I could rivet to the wall. Using the Scamp rivets, washers, & caps it would be water tight & uniform looking outside. Maybe just a couple of D-rings to take the lateral load that you dropped a pin through? Bert
https://www.lodimetals.com/1-mountin...hoCPUoQAvD_BwE
bertherr is offline   Reply With Quote
Old 08-08-2020, 11:32 AM   #4
I think the response to static loads would be fine but you would need to attach the vertical supports to the trailer to restrain the dynamic loads while in motion and in response to kids climbing and such.
Overall a good idea, I hope it works well for you.
Thane is offline   Reply With Quote
Old 08-12-2020, 07:29 AM   #5
Markz's Avatar
Do you want it to be a permanent modification to the camper or reversible some time in the future? This will dictate the direction your installation will go.
Markz is offline   Reply With Quote
Old 08-12-2020, 12:02 PM   #6
When I rebuilt my Scamp 16 I changed most of the interior and a part of that was installing bulkheads and twin beds by removing the Ensolite insulation, roughing up the fiberglass and gluing and screwing (from the outside into the wood structure) for a more monolithic structure.
If you bond the frame to the shell and carry the loads to the floor structure you will stiffen both the bed frame and the camper shell.
As far as I know none of the small fiberglass campers have any of the interior structure bonded to the shell, although some of the wooded cabinets in the deluxe Scamps are screwed from the outside into the wood.
Old 08-12-2020, 01:16 PM   #7
Nice job on your rebuild.
Just for info, Escape trailers have wood support blocks fiberglassed to the shell which are then covered by wall covering. The cabinets, benches and such are then attached to those blocks. There are no fasteners through the shell for these items, only vents and such.
Old 08-12-2020, 01:38 PM   #8
Trailer: Uhaul
I was going to use stainless steel screws with large washers to hold blocks that I'd brace the bed to; however, I thought gluing blocks of wood to the Fiberglass would be even stronger.
I'm going to use 3M 4200 to adhere a pair of foot long blocks to the fiberglass wall. I've exposed the fiberglass by cutting and peeling away the fur and ensolite. This puts the lateral load across a large surface area then the screws.
I'm also going to screw the bunk framing into the dinette seats for extra measure. Overall, I'm thinking this should be pretty solid with the vertical load going to the floor and dinette seats, all while laterally braced.
Old 08-12-2020, 09:08 PM   #9
Sounds good, well thought out.
Boler bunk/couch: does top bunk fold down? Uncle Cereal Problem Solving | Owners Helping Owners 4 01-12-2016 10:34 AM
Converting non Bunk to a Bunk arrangement Trillium-Pettis Modifications, Alterations and Updates 2 05-29-2015 08:49 AM
Scamp 16' Side Dinette Bunk Mod? lk123 Modifications, Alterations and Updates 2 08-06-2014 06:51 AM
2008 17' Spirit DLX with Side Bunk Beds PaulS Classified Archives 2 01-09-2011 04:26 PM
» Trailer Showcase
Trillium
LucilleL
Casita
Ed F
