Here's a couple quick pics of the Storm before the Calm as the
electrical system develops.
There's a shot of the storage area under the passenger side rear bench which is opposite (of course) of the driver side rear bench that houses a 30 gallon water tank. On this
electrical side of it I've got one more
battery going in which will be a total of four 100 amp hour SLA Batts and together they will weigh 240 pounds over the right side of the rear
axle. That will serve as a nice counterbalance to the 250 lb of water that can sit in the 30 gallon freshwater tank over the left side of the
axle.
If I'm really going to pull this thing with a Volkswagen Beetle I'm going to have to yank out three of the batteries and run the fresh water tank empty until I get to the campground. But that's very doable in a half hour preparation before I leave. I normally tow with a full-size pick-up truck so
weight is no issue with that thing.
You can ignore the snakes nest sitting on top of the batteries as I've got some solutions for that on the way.
Also, even though these are sealed lead acid batteries, that really means that they are valve regulated and can pop out some hydrogen gas and other nastiness in the event they hit an overcharging situation. Those will be boxed in and there'll be a vent in the floor and another vent out the side so that air circulates within that box, keeping the batteries at atmosphere temperature and also keeping any gases away from the passenger compartment outside the box.
Running down the back you can see all the 12 volt wires heading to the
tail lights in the back and waterpump around the other side. The yellow one is the shore power feed coming around from the 30 amp outlet I put in the side of the camper in the utility closet on the driver side.
Tucked way down there in front of the batteries is a green 2000 watt pure sine inverter that feeds the household current when I'm
boondocking it. It has to be pure sine wave cuz I use it to run the compressor motor in the chest freezer.
The next pic shows what I'm doing with the storage cabinet that exists right by the front door. As far as I can tell it would be good for putting spices in and that's about it because it's not very deep. It does serve a structural function for the trailer so it has to be there.
I've decided to use it as my
electrical system center and it's going to house just about everything.
Down below there's an 30 amp (120vac) automatic transfer switch that will pop between the shore power or the inverter power off the batteries depending on which one is flipped on at a given time. That piece is designed so that you can be running on shore power all the time and then if you turn on a
generator it will force the switch over to the
generator power and keep it there until you turn off the
generator. In this case, however, I don't have a gas generator, I have
solar replenished batteries. I do not want the
solar system to be holding that relay closed when it's running because that absorbs energy, even though it's a small amount it's a constant drain. So I have the switch hooked up backwards, basically allowing the inverter to be the default setting but when shore power is plugged in it forces the relay into the closed position to allow shore power to feed the system. It won't go back to the inverter feed until shore power is unplugged.
That automatic switch will never let the inverter and the shore power be hitting the system at the same time. In conjunction with that it is my intent to have the
battery charger hooked up to a relay that only is triggered when the shore power clicks on (if I can get that sorted out my mind) and that will be another safeguard so that the
solar power batteries are not running the
battery charger on the inverter trying to charge the batteries that are running the inverter, etc. ad infinitem. I forgot to unplug the inverter and the charger when I plugged into shore power one time in the Long Long Trailer and fried a really really nice ( I mean a really ridiculous never-able-to-get-one-again nice) inverter that way and I still have it in the garage hoping that one day I'll track down a replacement board for it. I don't want it to happen again. I have the relay for that circuit but it's not pictured yet.
Up top you can see the 12-volt distribution panel, which in this case is a circuit breaker panel for boats on the right side. On the left side is an AC distribution panel, again for boats that one is a blue sea product. And I really like it. Both panels have voltage meters because it's fun to look at the voltage.
In towards the center you can see that I have taken GFCI extension cords and cut out the GFCI portion of it and wired it in each of my three AC circuits in this rig. Now all of my AC circuits are GFCI protected and I don't need GFCI plugs. That was necessary because the plugs I'm using have both an 120v AC outlet and USB fast charging outlets built into them but there is no room in them for GFCI.
Also demonstrated in the center of that picture is my use of extension cord plugs in place of boxes to serve as wiring connections for the household current. Rather using Romex and then twisting wires together and putting caps on them with electrical tape inside of boxes, I'm using heavy duty outdoor extension cords to run my circuits and I install plug ends where they meet to connect them together. It takes a lot less space, and allows me to modify the system at-will later if I want to.
I have three AC circuits, one circuit for outlets and another circuit for the
refrigerator and heater and the third circuit for the battery charger.
Down Below on the left side you can see the progressive Dynamics battery charger it's a 60 amp smart charger that has four stages for maintaining the batteries in tip-top shape.
Not shown is the
solar charging panel - it's a 30 amp solar smart charger that has multiple stages of battery maintenance.
Also not showing at this point is the battery monitoring system that just arrived. It will run off a shunt by the batteries and tell me how many amp hours I have left.
If my maker is willing, I'll knock out some of this in more detail and also show you what it looks like when this wiring mess is cleaned up, but I wanted to get this overview out of the way so I can just hit and run as different pieces are starting to roll.
