Camco Wave Catalytic Heater - Fiberglass RV
Old 03-25-2024, 02:09 PM   #1
Perryb67's Avatar
Trailer: 2016 Bigfoot 25RQ
Is anyone here using a Camco Wave Catalytic Heater in your trailer?
I know catalytic heaters can be a touchy subject, so PM me if you don't want to post here.
We've been using a small portable Martin catalytic heater for the past four years with no problems of humidity buildup or CO. I understand how to vent adequately, but have a second CO detector that's never gone off with the Martin. However, that CO detector has gone off when cooking on the stove or running our Mr Buddy heater with no windows/vent cracked open.
Again I'm looking for someone who is actually using a Wave heater. Mr Buddy now makes a catalytic heater, so I'd be interested in hearing about the Buddy catalytic heater too.
Thanks,
Perry
Perryb67 is online now   Reply With Quote
Old 03-26-2024, 10:30 AM   #2
TX
When I purchased my 2010 Casita (17') five years ago, it came with a Wave 3 mounted on a wall but no furnace. The Wave was fine for mild weather, but under 50 F OAT it was quite inadequate. Finally took my trailer to Casita factory just a few months ago and had a Suburban heater installed. Now I can be comfortable in any weather.
The Wave worked just fine, and perhaps a larger model would have been worth trying. But I camp off grid A LOT, and was tired of shivering through chilly mornings and evenings. I won't be without a furnace in the future, no matter the rig I'm using. I will say, though, that I'm finding the Wave to be a nice compliment to the Suburban furnace, providing a steady source of warmth that enables the furnace to cycle on less often.
Chris Delker is offline   Reply With Quote
Old 03-26-2024, 05:12 PM   #3
ShelbyM's Avatar
Trailer: Casita SD
Of all trailers, it's weird to think of a Bigfoot w/o a proper furnace.
If the shoe fits...
Old 03-26-2024, 07:52 PM   #4
Perryb67's Avatar
We're not replacing the furnace. It will be fully functional. We're just installing a Wave 3 or Wave 6 to save money on gas, have a silent heat, reduce amp use every night, and have a backup for the stock Dometic furnace. We've already had to add a Dinosaur board to the Dometic. We camp quite often in cold conditions.
Enjoy,
Perry
Old 04-01-2024, 11:24 AM   #5
Trailer: 13' Scamp 2003
Wave 3
I installed a Wave 3 in my 13’ scamp about five years ago. It works great and I have camp in the snow down to temps in the high teens. Much colder might be a problem. Condensation is an issue but not too bad. I mounted it below the door on the closet cabinet. I keep the stove vent window open and figure that the intake air is coming from the fact that the door doesn’t seal that well even with the new weather strip I installed. One worry I have is that the bedding will droop down and make contact. I have used a piece of plywood wedge between the cushions and the closet to hold the bedding in. I will make a wire cage for a permanent fix. I often just turn it off during sleep time. Heeding the safety precautions and the suggested maintenance is mandatory.
I have two C O detectors and never had any issue.
tweistar is offline   Reply With Quote
Old 04-02-2024, 07:35 AM   #6
TZBrown's Avatar
Trailer: Escape 21 and Northern Lite truck camper 2014 2500 HD Duramax
We have a wave 3 in our 21 ft escape.
It performs very well, though we don't run it through the night.
When the temps get to about 10F it is not big enough even on high to make the whole trailer comfortable, even when using the caframo fan to circulate the air.
If it is positioned in front of the dinet area we stay toasty warm though.
Both the Wave 3 and the furnace running will warm the place very fast
As a stand alone heater I would say the Wave 6 would be a very good choice
Life's A Journey: It's not to arrive safely at the grave in a well preserved body, But rather to skid in sideways, totally worn out, shouting, Woo Hoo!....What a Ride!
https://www.flickr.com/photos/56844387@N04/albums
https://www.youtube.com/user/TZBrown01/videos
TZBrown is offline   Reply With Quote
Old 04-02-2024, 08:54 AM   #7
Perryb67's Avatar
On the negative side, our 25' Bigfoot has quite a bit of cubic feet to heat, but on the positive side with the >1" of closed foam insulation and true double pane windows is much, much warmer than our Escape 5.0, our 17' Casita, or our 16' Scamp.
The idea is to use the Wave as the main heater, but the furnace would kick in when the Wave couldn't keep up. On <20 F nights our amperage use can easily exceed >80 amps a night using the furnace and Terry's CPAP. Despite our 600 watts on the roof and a 100 watt portable we have run out of juice at night twice since we bought the Bigfoot 15 months ago. I don't like our F150's 400 watt inverter to charge our batteries with the Victron IP22 thirty amp charger, idling for 4-8 hours a day. Both times we killed the batteries (two 200 amp SOK LiFePO4's) we were camping in heavy shade where the panels put out around 80-120 peak watts during the day. We also liked the silence of our Martin portable catalytic heater, but it runs out of LP at 5-6 am, and is always in the way, so we desire a more permanent solution.
Since we've been using a Martin catalytic heater for the previous 4 winters with our Escape, we have two CO detectors, with the second for additional safety. We cracked the one window by the awning arm about 3/8", with the ceiling fan open around 1/2-3/4 inch, so the air comes in the window and goes out the vent. One detector has a readout for the current CO level. Only when cooking with the stovetop or using our Mr Buddy heater (that no longer comes with camping) has the one detector ever shown any excess CO in the air. It's actually gone off a couple of times when we weren't using the Martin, but failed to open any vents/windows when Terry was cooking.
The more I hear people talk about their Wave 6 the more it looks like a Wave 3 will heat like we want. On other forums the Wave 6 owners said it was too hot on nights where the temps were above 40 F and would be more so with the super insulation of our Bigfoot.
Thanks for your input!
Perry
Excessice Propane Usage in Camco Wave 3 Heater semievolved Problem Solving | Owners Helping Owners 7 12-02-2022 10:28 AM
Camco Olympian Wave Three Propane Heater for our Trillium 4500 Shangie Modifications, Alterations and Updates 2 11-30-2022 12:09 PM
Installation of Camco 57331 Olympian Wave-3 3000 BTU LP Gas Catalytic Heater stevescrook Problem Solving | Owners Helping Owners 2 05-25-2020 07:35 AM
Camco Olympian wave heater install hiker22 Modifications, Alterations and Updates 12 04-11-2018 01:53 PM
Have Olympian Wave Catalytic Heater User Guide rudock1 Forum Admin, News & Announcements 1 10-22-2008 04:37 PM
