Originally Posted by Jon in AZ
If you call, verify whether it will work on your 16'er, which may not have exactly the same frame configuration under the door. Also, I think you probably need the high lift axle for the double step entry. OEM is single.
Yep, LHC use to specify what
Casita trailer configurations were acceptable for their step, but it would be wise to confirm with them when ordering. Our Casita is the 17' Liberty model and has the Dexter 3,500 pound TORFLEX 10 degree down
axle AKA "High Lift Axle" that Casita trailer would often include for free if requested when ordering the trailer.
Another option might be a step from Lippert:
https://www.lippert.com/blog/how-to-replace-rv-steps
Gayle & Bob
"Los Gatos Casita"
