Ceiling carpet adhesives and Lights - Fiberglass RV
Old 03-15-2017, 11:02 AM   #1
Trailer: 13' Uhaul
I'm in process of restoring my U-Haul trailer - trying to keep it as much original as possible. I have the original ceiling carpet that has fallen off and is still in good condition. I would like to reinstall; however, I'm not sure what adhesive to use and the process of holding it up to the ceiling while the adhesive bonds. If anyone can provide any information would be greatly appreciated. I will consider other ceiling options that maintain some originality look.
Also, I would like acquire the brake lenses and the smaller little lights. Does anyone know where to find them?
Thanks, Raul
ralob is offline   Reply With Quote
Old 03-15-2017, 11:08 AM   #2
original tail light lenses are not available. Someone is attempting to make replicas but has not done so yet. The small lights are available from Uhaul, but are just a standard light made by Arrow. Adapters are available to convert the original tail lights to a standard round light. You need to join the Uhaul Facebook group for all this info.
Old 03-16-2017, 09:30 AM   #3
Trailer: Country Coach
Why not replace the carpet with DiBond panels ? Panels come in different thicknesses and a variety of colors and finishes,
Carpet in an RV is ridiculous. It's an RV and gets dusty and dirty and impossible to clean. DiBond will never rot or mold and is easy to wipe clean and if u use a lite color reflects lite. Brushed aluminum, or brushed stainless finish DiBond panels, make an excellent splash panel.
NomadWizard is offline   Reply With Quote
Old 03-16-2017, 09:39 AM   #4
YourHighness's Avatar
Trailer: Burro
Iowa
I plan on using acoustic carpeting on my Burro and holding it up with contact cement as soon as it gets warm enough.
Rudy
YourHighness is offline   Reply With Quote
Old 03-16-2017, 10:22 AM   #5
francene's Avatar
Trailer: 13 ft Compact II
carpet
When attaching foam-backed vinyl to the interior of my Compact II, I used a Loctite cartridge in my caulking gun. The product was something like 'quick grab' Loctite. Contact cement sounds fine, though. Then use thin plywood panels or strips propped up with 1 x 2's or broom handles to push the material against the ceiling until it is dry. You get the idea? Do a section at a time.
Hope this helps!
Fran
p.s. Just looked it up: Loctite Power Grab; worked surprisingly well.
francene is offline   Reply With Quote
Old 03-16-2017, 10:23 AM   #6
Good luck keeping it clean and free of mold.
Put up the DiBond with 'Reflectix', for insulation, in behind.
Old 03-16-2017, 10:35 AM   #7
theresa p's Avatar
New Brunswick
NomadWizard----noticed that you are relatively new here. Welcome. However, just a little hint...taking the "bite" out of your posted comments would be appreciated.
This forum tries to pride itself on not judging or criticizing but in making helpful comments without any overt snarkiness. We all are here to learn and share...but in a positive, welcoming environment.
Old 03-16-2017, 11:47 AM   #8
Name: Bill & Jeanie
Trailer: Building camper in Ram Promaster van
Contact cement is normally applied to both surfaces then allowed to dry to a tacky condition. Sometimes it absorbs into the surface and must have a second coat to function properly. Be very careful in positioning as once it makes contact it is almost impossible to remove. Sometimes installers use smooth separator strips (such as from venetian blinds) and then remove them one by one. There will be no need to prop the material in place once the two surfaces are in full contact.
Contact cement comes in both oil and water based versions. I personally prefer the oil based type but be sure to use a respirator as the solvent is lacquer thinner or something similar. I personally would use 3M 90 spray adhesive for your application. It is essentially a contact cement but the spray application makes it easier, particularly over head.
wbullivant is offline   Reply With Quote
Old 03-16-2017, 12:29 PM   #9
Trailer: Burro
Iowa
Thanks for pointing out the process. Sometimes I make assumptions about people's experiences which are not necessarily true.
Rudy
Old 03-16-2017, 02:09 PM   #10
[QUOTE=theresa p;631370]NomadWizard----noticed that you are relatively new here.
And apparently doesn't own a molded fiberglass trailer, let alone a Uhaul, so his advice of material, from what I can see of it by doing a google search, will not work for the OP.
Old 03-16-2017, 02:47 PM   #11
Trailer: Burro
Iowa
Contact cement.....I personally would use 3M 90 spray adhesive for your application. It is essentially a contact cement but the spray application makes it easier, particularly over head.
Will this work better than the liquid contact cement you think? I've never used this before and I'm a little leery. It's devilishly hard to change if there's a mistake and I don't like to have to redo my work. Your thoughts are appreciated. Thanks
Rudy
light, lights
Suggestions for ceiling carpet adhesives ralob Modifications, Alterations and Updates 12 03-21-2017 05:26 AM
interior walls and ceiling- paint? carpet? CS86 Problem Solving | Owners Helping Owners 4 07-12-2013 04:17 PM
Casita carpet....... Walls and Ceiling Robin G Problem Solving | Owners Helping Owners 52 06-18-2008 05:12 PM
Glues and adhesives Legacy Posts Modifications, Alterations and Updates 16 07-25-2003 09:30 PM
Casita carpet....... Walls and Ceiling Robin G Modifications, Alterations and Updates 0 01-01-1970 12:00 AM
