Originally Posted by BeatheBoler
Thanks! I have seen that post. I’m confused by the various terminology though, about the bench and the cut out, and what is safely removable.
I don't know Bolers, only scamps. In our
scamp the floor under the bench is high at the two ends and low in the middle. This low section is referred to as a "cutout" or "porta-potty cutout" because people use that space to store their porta-potty. We use it as shoe storage. Having that cutout gives a nice low spot for your feet while seated in a dinette configuration so you don't have to raise the seating positions above the level of your existing couch.
If you have a cutout then you can easily tie the new seating structure to the old structural attachment points: wood embedded in the
fiberglass shell on a
scamp. I don't know it the
boler is different. The idea behind using those existing attachment points is that they are already there and presumed to be secure. Also, a lot of structures in these little things tie together in ways that aren't obvious at first glance, so it seems that using the existing mounting points is less likely to leave other things unsupported or unsecured.
For our
scamp the couch supports our bathroom wall as well as our screen door surround, so we would have to be careful to keep those supported. For others is may be less critical.
If you don't have a cutout then your seating will need to be raised to have a comfortable seating position. timing into the existing structural mounting points ma be much harder. It will take more planning and consideration and you may decide it is not necessary.
If you go the office chair route, which looks cool as all get out and really comfy, then you may want to place a trim board around the interior shell of the camper where the bench is attached to provided added rigidity to the front wall. I doubt it is needed, but I would sleep better knowing it was there if it were my trailer. It may be cool to make it a low shelf to place things on, but that would lead to my wife calling it cluttered.
