Originally Posted by Tomo2
Interesting - so you are using this on top of your subfloor/under your flooring?
I have not used it yet. In Trilliums, there is a sheet of ¾" plywood in the floor. It is sandwiched between the floor of the trailer, and the outside shell on the bottom. Some have had it rot to nothing. I have been considering the idea of a 100 year trailer rebuild. I decided that it would be necessary to eliminate any wood in my trailer rebuild. The wood in the floor and the inside framing around the
windows are the only place that
Trillium uses wood. I would install the grating in place of the plywood. To do this, I would have to cut the bottom off the
Trillium.
It should be noted that since Trilliums are not much more than 6' wide, I would not require the 8' long grating. Fortunately it is
sold in many lengths and widths. I don't believe that Granger is the least expensive place to buy it though. When I am in a place to purchase, I will be shopping around.
In exploring alternatives to wood in the floor, I looked at the foam that is used in foam sandwich construction on boats. It is almost as expensive as pultruded grating. The grating seemed like a stronger solution, so I settled on that idea. It is ¼” too thick, but I think I can compensate for that during the install. What I am looking for is a
Trillium 4500 with the floor rotted out, to try this on. Most, "For Sale" ads don't advertise this.
