Counter redo in Compact II - Fiberglass RV
Old 07-07-2020, 03:58 PM   #1
Denece's Avatar
Trailer: Compact II
We are finally replacing the counter, sink and stove in our 74 Compact II. I got the stove out. The sink looks straightforward. But what holds the counter in? Is it glued? Are there screws I didnít see?
Advice appreciated
Denece is offline   Reply With Quote
Old 07-08-2020, 02:51 PM   #2
francene's Avatar
Trailer: 13 ft Compact II
Yes, Denece, the counter is screwed in from below.
Good luck,
Francene
74 Compact II
francene is offline   Reply With Quote
Old 07-08-2020, 05:01 PM   #3
Denece's Avatar
Trailer: Compact II
As it turned out it was both! I found most of the screws and got them out, there are some remnants of the particle board stuck to the frame on a glue line , AND long brads holding the galley upper fiberglass liner to the counter. Who knew?
Old 07-08-2020, 05:23 PM   #4
francene's Avatar
Denece, looks like you're on your way. It was 11 years ago when I renovated my trailer, so my memory is not too sharp. But I took a peek under my new counter, and could see I used glue and screws to reassemble.
Good luck!
Francene
Redo of 1978 UNIK David & Terry Care and Feeding of Molded Fiberglass Trailers 8 08-12-2013 05:55 PM
Starting the Redo Gina D. Modifications, Alterations and Updates 16 02-18-2007 04:21 PM
If you could just completely redo it? Coach George Jessup Modifications, Alterations and Updates 16 04-30-2006 10:36 AM
official redo, pg. 1 (boler) Erik J Modifications, Alterations and Updates 3 02-24-2006 10:26 PM
To re-do or to not to redo, she questions Legacy Posts Problem Solving | Owners Helping Owners 24 05-20-2003 02:12 PM
