Cutting Door in Rear of Bigfoot - Fiberglass RV
Old 01-28-2020, 12:46 AM   #1
Hi there
I recently purchased a 2003 Bigfoot 27’ RV. It is on an E450 chassis.
I’m all done with the chassis (6” lift, sway bars, Trac bar, front clip etc)
I am now moving on to the coach. Before I get into painting, new countertops etc. I was going to cut a rear window in the very back of the coach, but got thinking a door would be a lot handier. I emailed Bigfoot a couple times but never heard back, I am wondering if this will affect any structural integrity of the unit? The door would be from inside floor to inside ceiling so approximately 72”, and then 36” wide. I can order the door which is 1.5” insulated from Challenger Door.
If I do need some integrity, I can always build a heavy duty steel C channel frame in the opening that the door would sit in. But not sure if this is necessary, I don’t know much how this fibrecore system operates.
Thanks for any suggestions and advice, looking for sound advice and not just “I wouldnt” without any background.
I’ll post some pictures of the entire RV when complete,
Jaredsmits is offline   Reply With Quote
Old 01-28-2020, 04:51 AM   #2
CindyL's Avatar
Trailer: 16 ft U-Haul VT
You might want to post this question on the Facebook Bigfoot groups and also BOCI (http://www.bigfootowners.com), if you have not already done so. While you might get some responses here, this forum is for molded fiberglass campers, not Bigfoot fibercore RVs. I know that there are some members in both places who own this kind of RV.
Welcome to the Bigfoot family.
CindyL
1988 Bigfoot Silver Cloud, "The Egg Carton"
CindyL is offline   Reply With Quote
Old 01-28-2020, 08:25 AM   #3
Trailer: 2013 Escape 19
" I emailed Bigfoot a couple times but never heard back,"
It is common for manufacturers to NOT answer emails. I had an email from Casita answered FOUR years later.
Get on the phone and call them. The ones I have called (including Casita) were pretty responsive.
Old 01-28-2020, 10:01 AM   #4
Trailer: 2020 25 RQ
In Grants defense, he will respond to emails within hours. Ever been to the factory? I would suggest that he needs an assistant to deal with communication only, but as such he IS the person of contact...if he s not in the office, he's managing builds.
Russ Foster is offline   Reply With Quote
Old 01-28-2020, 10:40 AM   #5
Sad but true.. I fail to understand why companies have web pages, contact forms and publish their email address, only to ignore it all.
Last week I used web contact forms or email to reach out to an accounting firm and four home remodeling companies... a week later the response rate is 3 out of 5. To bad for them since I have options. In you case, yes... call.
Old 01-28-2020, 05:22 PM   #6
Trailer: Lil Snoozy
MD
But it doesn't have to be that way. Our new TC Teardrop will be done this week and I have to say that the owners are super responsive. They answer the phone. They post and respond on Facebook. They respond to email including weekends sometimes.
(We are keeping the Snoozy, The TC is for off-road trips. And don't even think about the former Lil Snoozy responsiveness.)
Air Doug is offline   Reply With Quote
Old 01-28-2020, 05:46 PM   #7
Company owners hire web designers. Web designers give company owners what they believe they should have, not always what they will actually use. In every place I've ever worked the IT department often seemed to operate in a parallel universe...
In this case, contacting Bigfoot is probably a waste of time, since the new, post-bankruptcy (2009) Bigfoot only builds all-molded trailers. This unit is a different RV type manufactured using a different build process under different ownership.
The groups Cindy linked are probably your best bet.
Random thought...I've always thought the B25RQ should have a second side door in the bedroom.
bigfoot
Cutting a skylight hole in 17" Bigfoot trapper Modifications, Alterations and Updates 6 09-20-2018 07:22 PM
Front rear, rear wheel, all/four wheel for towing? Debbie in Florida Towing, Hitching, Axles and Running Gear 23 04-22-2018 04:34 PM
Cutting a Bigfoot 25B175FB to install a weight distribution hitch? rdf0011 Towing, Hitching, Axles and Running Gear 12 09-02-2017 01:24 PM
Cutting a hole in roof of Bigfoot 5th wheel Ham Bonz Problem Solving | Owners Helping Owners 0 06-11-2017 12:19 PM
Bigfoot cutting board out.... Franswa Modifications, Alterations and Updates 15 06-13-2016 05:08 AM
