Dometic fridge removal. - Fiberglass RV
Old 06-04-2018, 09:59 PM   #1
mensie's Avatar
The dometic 211 fridge is not working in our Trillium, which is no surprise after the trailer had not been used for many years.
I’m ready to pull it out of its spot and see if I can revive it by turning it up side down.
Now the question is how is it fastened? I removed 2 screws from the back and 2 from the front under neath the fridge door. I disconnected the propane and electrical, I would think I could just pull the thing out, but it won’t budge, are there any screws that im missing? The fridge is in there pretty snug.
mensie is offline   Reply With Quote
Old 06-05-2018, 03:12 AM   #2
Trailer: Boler 13 ft
I did mine about 4 years ago and I seem to remember there was screws on top and I needed to pull the silverware draw out. Also remember it was a real tight fit around the fiberglass and had to push and wriggle it to get it out.
Old 06-05-2018, 07:43 AM   #3
Some models have screws above the door covered by plastic trim caps.
Old 06-05-2018, 10:10 AM   #4
You know the old saying, "The man who is his own lawyer has a fool for a client." All trailer appliances should be either run continuously or at least exercised monthly. Then they should be serviced by a trained authorized serviceman once per year. He does all the routine maintenance and factory upgrades that have been published over the past year.
If your Dometic has not been used in years I can think of at least 4 components that are time-replaceable that will need to be changed for reliable operation. Dometic makes a very fine product. Mine has made ice in 6 hours on propane for many years. But they often fail because they are installed incorrectly and improperly serviced. Caveat Emptor
Stephen_Albers is offline   Reply With Quote
Old 06-05-2018, 12:18 PM   #5
David Tilston's Avatar
Please do detail the four components that you refer to.
I have several RM211's and RM36's, and one RM24. Some have sat for several years unused and unmaintained. When plugged in, and level, they freeze water.
Since a major failure of the cooling system is frequently caused by corrosion of the heated section. I can't see running them continuously being very good for them.
There are many examples of absorption fridges that are on the order of 40 years old that work fine. I see RM211's on kijiji regularly.
Mensi, Since you are in Alberta, if you can't get yours working, then maybe take a look at this one:
https://www.kijiji.ca/v-trailer-part...ationFlag=true
Old 06-05-2018, 12:31 PM   #6
I removed our RM211 recently and it was a struggle to get it out. A lot of pulling and pushing and a dose of patience and it will eventually come out. Once out I turned it upside down and waited until the gurgling stopped then right side up and presto - it worked. As I intend to remove the fridge periodically I shaved off 2mm of fiberglass from the cabinet front to make it easier next time.
Elvin
omache27 is offline   Reply With Quote
fridge, trillium
Scamp Fridge Removal Ideas summer scamp Modifications, Alterations and Updates 22 07-28-2016 05:39 PM
73 Boler fridge removal? Vernois Problem Solving | Owners Helping Owners 2 09-16-2013 10:38 AM
Fridge door seal - removal Scouter Dave Care and Feeding of Molded Fiberglass Trailers 7 05-07-2012 02:29 PM
71 Boler 13' Floor Removal/ Shell removal mikeandmadi Problem Solving | Owners Helping Owners 1 05-23-2011 10:28 AM
Boler 13 kitchen base removal (with 3-way fridge). I'd love to hear any tips! Raya Care and Feeding of Molded Fiberglass Trailers 19 09-26-2010 07:58 PM
