Fantastic Fan thermostat? - Fiberglass RV
Old 05-13-2020, 08:32 AM   #1
Trailer: In the Market
I am looking at my power needs for my system and it would seem beneficial to have the FF thermostatically controlled. I have the model without a built in thermostat.
It is easy enough to find the wires going to the fan, intercept and install a thermostat. Then you would leave the fan onto the setting that you want and the thermostat would turn it on/off as needed. Would want a decent thermostat, ideally with adjustable dead band to limit cycling. Would likely install a bypass switch so can not use the stat if desired also.
See any issues with this concept? I dont think there are any fancy electronics that would be harmed, it would be similar to the switch activating to run. It however would have many more on/off cycles which may add wear.
kipper is offline   Reply With Quote
Old 05-13-2020, 09:33 AM   #2
My mod was to replace the three speed resister switch with a PWM controller. Now I have infinite speed control to zero to max fan motor RPM. I had to buy a second controller s the first one from China would not run the fan when the temp in the camper got much about 95 f or so. What do you expect for well under $10.
Old 05-13-2020, 01:06 PM   #3
nice mod gordon2
are there any issues at the bottom end speed range?
Old 05-13-2020, 04:42 PM   #4
Originally Posted by kipper View Post
nice mod gordon2
Maybe eventually but so far, no problems for me. I've run it a good bit slower than the original low speed while sleeping. Of course I have no specs on the fan motor so don't know if there is a minimum recommended speed. It will go slow enough that no air is moved but running it at a speed where even a very minimal amount or air flow occurs I think will not hurt the fan motor.
Demo video:
https://youtu.be/NMGRQJaC_ik
Old 05-14-2020, 07:51 PM   #5
nice vid, looks pretty sweet!
I might give it a try at some point... any details on the PWM used?
Old 05-15-2020, 06:45 AM   #6
Just one from China (eBay) which is rated to handle the amps.
For mod details try google.. lots of people have documented the mod.
Old 05-15-2020, 06:53 AM   #7
Thanks! seems like a cheaper alternative to the thermostat idea and I dont want to hear it coming on/off all night. Would much prefer to run it at a low speed all night, and keep the power consumption to the minimum
Old 05-15-2020, 02:22 PM   #8
Found this thread online:
https://tab-rv.vanillacommunity.com/...n-mod-10-bucks
which does exactly as you have Gordon2 and the link to the PWM appears to be an active link still to amazon
I think this mod is coming to an RV near me... not much to lose. Love getting the power draw down to 0.5A = smaller battery required for my multi-day adventure plans.
Old 05-20-2020, 01:35 PM   #9
I did this. Before I had the fan, I’d replaced the furnace thermostat with the digital programmable one from my house (house got upgraded). When I installed the fan I ran the power input to a 12v relay, and the A/C side of the thermostat. Works great. Now it controls the furnace and the fan. I just want it to turn the fan off if/when it gets cold at night without having to get out of bed.
toddq is offline   Reply With Quote
Fantastic fan orrrr the Max air fan? DonnaMarie Problem Solving | Owners Helping Owners 42 05-11-2017 12:03 PM
Installing Maxx Air Fan Mate 850 Vent Cover Over Fantastic Fan CampyTime Modifications, Alterations and Updates 7 10-10-2013 10:43 AM
Fantastic Fan a little bit less fantastic Davie B Problem Solving | Owners Helping Owners 10 05-15-2013 04:25 PM
Fantastic Fan Thermostat Switch Question Bruce H Care and Feeding of Molded Fiberglass Trailers 4 09-09-2010 10:01 AM
Fantastic Vent vs. Fantastic Fan Ami P Care and Feeding of Molded Fiberglass Trailers 5 06-30-2008 11:33 AM
