Flooring/decking - Fiberglass RV
Old 06-26-2020, 04:02 PM   #1
Trailer: Sunland Express
Flooring/decking
Has anyone tried to use the plastic decking for a floor when removing the original plywood deck. I would think this would eliminate the rotting problem. The decking could be overlaid with underlayment to provide a smooth surface for your choice of flooring. It could be bolted and glued in place
Would the thickness of the decking pose a problem when putting the body back on? I don't know. Anybody want to run with this idea? Just putting it out for discussion.
Happy Trails, Bing
Bing M. is offline   Reply With Quote
Old 06-26-2020, 05:16 PM   #2
John in Michigan's Avatar
In most molded fiberglass campers, the plywood subfloor serves several purposes:
- provides a subfloor for attaching the flooring
- supports the weight of the flooring and furniture
- supports the weight of the occupants
- supports the weight of the fiberglass body, upper cabinets and items attached to the roof
While plastic decking has many advantages, the challenge would be finding a product has sufficient strength to carry additional weight of the fiberglass body, upper cabinets and items attached to the roof.
Trillium 4500 Journal
https://www.fiberglassrv.com/forums/f...nal-81345.html
Old 06-27-2020, 08:15 AM   #3
Bing, your profile says you have a 30í fifth wheel. Are we talking about that trailer or another all-molded trailer?
From what little I know about composite decking materials- Starboard is the one Ive heard of, but there are probably others- they donít have the same structural properties as traditional wood-based products. In particular I recall they require more frame support (shorter span) to prevent bending when you walk on it.
Be sure to read the product description and installation requirements carefully.
Decking on the tongue of trailer ShawnKK Modifications, Alterations and Updates 27 05-13-2013 05:41 AM
Flooring: Interlocking PVC Floor Tiles? S Sato Modifications, Alterations and Updates 5 03-13-2006 02:07 PM
Flooring Legacy Posts Modifications, Alterations and Updates 59 01-28-2006 08:15 AM
Flooring removal Legacy Posts Problem Solving | Owners Helping Owners 1 06-01-2003 07:40 PM
trailer flooring and insulation General Chat 0 01-01-1970 12:00 AM
