Originally Posted by CARSMills
I also use an AM FM RV Antenna With Adjustable Ball Base... works well, and adjusts down when I cover for winter
This is close to what I am using. I got mine at a local RV dealer and mounted it on a bracket bolted to the back of the
awning. I ran the cable in through the
refrigerator vent. BE CAREFUL TO SEAL THE CABLE RUN! This area must be airtight to the living space so that combustion products from the
refrigerator do not enter the living space. Know how far the cable run is so that you can order an extension if needed. Also order a non-extendable type antenna, they survive the trees better.
https://www.amazon.com/Leisure-Time-...338260&sr=8-31
