1999 13"
Scamp. The fresh water connection valve cover is broken! We went ahead and got started (thank you for answering my post about removing the rivets!), however we have run into an issue with disconnecting the blue water hose from the cover. I saw on these forums that one of the first things we should do it disconnect the hose from the water tank. Are we detaching it from the tank side or from the side where it connects to the fresh water connection valve cover on the exterior of the
Scamp?
I see that there are 2 metal bands around each end of the hose, but once we loosen those it's not clear how to detach the blue hose itself. I'm hesitant to just pull on it without knowing more. Again, we are trying to remove the hose in order to replace the fresh water connection valve cover. How do people do this?
