07-02-2018, 02:59 AM
Trailer: 1973 13' Trillium
Help! Trailer fell off truck/needs front corner fibreglassed
Hi! Yes our 13' Trillium came off our hitch and decided to ride along side our truck (the last check indid was put the leg down/crank to see if the tongue came off the ball/it did notvso I thought I was good to go........NOT!)
Anyways.....the front corner above and belowv the belly band now need fibreglassing due to a large gaping hole. Has anyone done anything like this or know where I could take it for repair that won't charge 3 arms/4 legs?
Thanks for any help......I live on Vancouver Island, BC. (The other option might be to find a junk trillium of years ____________ and cut out the entire corner I need).
07-02-2018, 04:10 AM
That's not good Andrew. Being you checked the connection with the jack, I have to ask if the ball size is correct. If so, the couplers fork may need to be adjusted or rebuilt as it may be worn out. Really can't give you any good info on FG repair without seeing a few pictures of the damage. FG is a pretty easy material to work with.
07-02-2018, 10:01 AM
Hi Andrew,
sorry about your trailer damage, it is hard to recommend a fix to your broken area without pix? and if you have the missing parts? Usually that would not be a difficult thing to fix depending on access from both sides. You might try a body shop that has experience fixing fibreglass cars like Corvettes and race cars. Next I would try a boat repair shop. Depending on how fussy you are, I would fix it myself using FG boat repair products from CTC. If you need to talk to someone let me know and you can call me. I am in Toronto (3 hour difference). I would paint the fixed area or whole lower front with a rock guard paint. Cheers George
07-02-2018, 10:02 AM
Trailer: 1978 Trillium 4500
Hi Andrew, not good news, but you are on the island. Any boat repair place can help you. If you type Fiberglass hole repair into YouTube you will find many video's on how to do it yourself. The thing I have learned with fiberglass repair is if you put too much on you sand it off and if you did not put enough on you add more. The trick will be getting the shape, and if you could get a mold of the other front corner then you will be half way there.
By the way if you are in Victoria, you can commiserate with the guy on Richardson near St. Charles who is repairing what looks like a hole and crack from a tree falling on it.
Good luck and keep us posted on how it goes.
Island Bolers and Friends on Facebook
07-02-2018, 11:25 AM
Trailer: Bowler 17
Manitoba
Its not that hard check the size of the hole tou can get the tuff you will need to do the repair at any bost shop fiberglass mat you want at less 3layers of mat so if the hole is 3 ft square than you will need 8 sq ft of mat resinyou can pick up at Canadian Tire and gel coat its very easy to do
hope this helps
07-02-2018, 12:20 PM
Did you keep the pieces of broken fiberglass that use to cover the hole?
07-02-2018, 12:27 PM
Mid Left Coast
I second the emotion re finding a boat repair guy who has experience repairing fiberglass hulls. and this should be much easier on an island than in a landlocked state
07-02-2018, 04:44 PM
Trailer: 2014 Parkliner 2016 Honda Pilot
So sorry to hear, Andrew. Hope you get things fixed soon. Two thoughts:
check out the “You can repair fiberglass” thread, http://www.fiberglassrv.com/forums/f...ass-52498.html to see if it’s something you want to tackle.
And check that the pin you’re using to secure the ball latch has a large enough diameter to fill the hole. I had something similar happen, and my RV repair guy finally figured out that there was enough slack with a small diameter pin to allow the the hitch to release in a really severe bump/jerk. (Just bent the jack stand, thankfully).
— Anne
07-02-2018, 06:18 PM
Trailer: Roamer 1
Smith Valley, Nevada
Andrew,
Just wondering if the safety chains failed too, or were they not there at all?
As far a fixing a gaping hole, you may be able to make a mold off the good other side and use that mold up against on the bad side where the hole is. This technique is sometimes used with boats and allows a complex curved shape to be easily duplicated or large open holes to be closed. Also, the inside of the mold you make describes the outside finish of the new built up area, so the patch comes out pretty nice and requires less sanding and filling.
07-02-2018, 09:32 PM
Please post pictures. It is hard to give useful advise without visuals.
07-02-2018, 11:25 PM
Trailer: Trails West
Originally Posted by Raspy
Andrew,
great advice, that is how I would also approach creating a patch to fit into the hole.
07-04-2018, 10:36 AM
Thanks for the info everyone.....sorry for the delay in responding but computer/acct set up problems. I will check the coupler fork as well as ensure the pin is large enough to prevent "play to possibly allow trailer to pop off. Safety chains were installed/inspected and ripped off the trailer + truck. Fibreglassing myself=?......may give it a whirl but am just going to drive from Vanc Island to Toronto as of July 9. I have pics of the damage on my cell phone but do not know how to get them attached to this thread....any help there would be greatly appreciated.
07-04-2018, 10:40 AM
Also-i did manage to grab most of the pieces off of the front corner and have them at home.
07-04-2018, 10:52 AM
Go here:
Posting Photos - Escape Trailer Owners Community
It's a different forum, but the process of posting photos is the same as here.
07-04-2018, 11:09 AM
Thanks Glenn.
07-04-2018, 02:06 PM
Glenn.....
I followed your steps and see I have an attachment waiting but I can't find the Submit button or Preview/Submit? Can I call you?
07-04-2018, 02:15 PM
Once you have uploaded your picture and closed the browse window click on preview to make sure you've done what you intended and then submit.
It's at the bottom of the message panel.
07-04-2018, 03:57 PM
Trailer: 2012 Escape 19
You'd have to form a backer in the correct shape, then lay impregnated FG mat over it. Edge blending can be interesting. If you must travel with it as-is, maybe get something stabilized inside the hole and lay strips of Gorilla tape over it to close it up? Seems like it might hold for a while if nothing hits it.
07-07-2018, 11:59 AM
Trailer: 2005 25 ft Bigfoot / 2008 Toyota Tundra Crewmax 4X4
We had fibreglass work done on a 17’ Boler a number of years ago at a large boat repair business in the Sydney area. I do not recall the name of the place we used. An excellent job was done, the repair was not noticeable and it was not painted as they matched up the fibreglass to the rest of the trailer.
We had insurance through our house insurance that also covered the Boler as an add on and the insurance paid for the repair minus the deductible. They did require a couple of estimates before approval of payment and we ended up going with the company we had the most faith in. One boat company wanted to paint the bottom half of the Boler as they did not think they could match the fibreglass colour. We did not go with that company!! As I recall, it was not an inexpensive fix. Best of luck.
07-07-2018, 01:01 PM
Name: Jim and Kathie
Trailer: 1979 Surfside
We had smaller repairs done by Randy Phillips, 5055 Culverton Road, Duncan. Good guy - does great work! 250 746-4777. We are very happy with what he did for us. Kathie Fielding, 250 749-4083
