Help with how to remove a Trillium Trailer 1300 refrigerator - Fiberglass RV
Go Back   Fiberglass RV > Maintenance | Restoration | Modifications | Problem Solving > Modifications, Alterations and Updates
Click Here to Login
Old 07-09-2021, 02:38 PM   #1
kimnmiller's Avatar
Trailer: 1973 Trillium
Hi I'm looking to see if there is an old thread or any pictures about how to remove a Trillium Trailer 1300 refrigerator. I can't seem to find any posts on the topic. I have a 1973 Trillium 1300 and I'd like to remove the original fridge to create more storage space in the trailer as regular ice coolers work just fine for my food / drink needs. Any posts / how to guides?
kimnmiller is offline   Reply With Quote
Old 07-10-2021, 09:08 AM   #2
Trailer: 2013 Escape 19
It’s simple. Two screws in the back, accessed from the hatch, two screws in the front, below the door (open the door). Hardly worth the effort to create a video on it. Push it out the front, disconnect 12v, propane and 120V first.
Except for a few rare examples, people creating videos do it for free. The monetized YouTube sites tend to focus on bigger tasks that attract more eyeballs.
Old 07-10-2021, 02:07 PM   #3
kimnmiller's Avatar
Thanks Bill!
Is the propane easy to disconnect or any special considerations / tools I should have? I haven't worked with propane lines before, so a newbie to this.
Appreciate the advice.
Cheers,
Kim
Old 07-12-2021, 07:40 PM   #4
Trailer: 1976 Trillium 1300
New Brunswick
Help with how to remove a Trillium Trailer 1300 refigerator
Hi the propane line is easy to disconnect you can leave it as is but it must be plugged with a flare fitting plug that threads in . Try a local RV or gas outlet for a plug . Once plugged the line " must be tested for leaks " with soapy water. If any bubbles appear with the line pressurized and flame absent . It will need to be tightened more. Do ask for help if you are not sure what to do. I would keep the fridge so it can be given to a future buyer as a selling point ! Iwould also put a screen on the door & vent if you don't replace these items. Yup keep these too !
getaway1 is offline   Reply With Quote
Old 07-13-2021, 10:18 PM   #5
kimnmiller's Avatar
Thanks and level fridge
Thanks Duane for the info and yes a great reminder to keep anything I remove.
I was told by the seller that the fridge would only work if the trailer was perfectly level. Is there any truth to this comment? I actually have never turned the fridge on to test it.
Old 07-14-2021, 09:15 AM   #6
David Tilston's Avatar
Perfectly level is safest. However, a few degrees off level is really not a problem. What you are trying to avoid is preventing the flow of liquids downhill. Take a look at the back of your fridge. As long as any tube that slopes downhill when level still slopes downhill, than it should be fine.
Old 07-14-2021, 09:29 AM   #7
Cap the propane line underneath the trailer. Much safer. If it leaks, its not inside the trailer. There is a T under the trailer where the fridge propane line is attached. If you are not comfortable doing it yourself, then hire a plumber/handyman to do it for you.
Old 07-21-2021, 10:33 AM   #8
Illinois
When I removed the frig from my 1976 1300 I replaced the T that fed the frig with a couling. Follow the propane line down through the hole in the floor to find the T underneath the camper. This technique eliminates an unnecessary propane connection (plug) that could fail.
cocorom is offline   Reply With Quote
refrigerator, trillium
Scamp Remove Refrigerator Put in Window AC jzaman1 Modifications, Alterations and Updates 5 07-29-2016 09:29 AM
Remove Refrigerator John Colangelo Electrical | Charging, Systems, Solar and Generators 6 09-01-2014 07:03 AM
How to remove and reinstall the "bubble" windows (Trillium 1300) coalminecanary Modifications, Alterations and Updates 13 10-05-2013 10:25 AM
How do I remove the body from the frame? 1971 Trillium 1300 coalminecanary Modifications, Alterations and Updates 26 06-11-2012 09:41 AM
to remove decals or not to remove johnsoba General Chat 15 06-08-2006 12:10 AM
