How much Bondo-Glass for a Belly Band - Fiberglass RV
Old 04-06-2020, 09:58 PM   #1
Trailer: Trillium 4500
This is a question for anyone who has removed and filled in the belly band on their Trillium. I have a 4500 and I am going to use bondo glass that I am hoping to get at an automotive shop. How much would you suggest that I buy?
Nanph is offline   Reply With Quote
Old 04-06-2020, 10:11 PM   #2
I got it at Walmart in the auto parts section. I used two containers full (bought one at a time). Comes in one quart size. I'd just buy one, use it and if you need more, get a second one. I used regular Bondo over the Bondo glass to do the finish work.
No need to pay more at a specialty shop, at least here in the USA. I would think Walmart Canada should carry too.
Old 04-06-2020, 10:56 PM   #3
Thanks for the information. I've never worked with bondo-glass before. I am hoping that I can use any remaining material to patch a leaking canoe. I'll have to research that also! if I don't cover the belly band repair with a layer of straight bonds will it leave 'hairs'?
Old 04-07-2020, 05:02 AM   #4
With my amateur technique, I found the surface rougher with the Bondo glass than with regular Bondo.
Old 04-07-2020, 07:32 AM   #5
Trailer: trillium4500
I used fiberglass jell it does not run got it on amazon
lables is offline   Reply With Quote
Epoxy, Gel Coat, Bondo, fiberglass repair KevinScamps Modifications, Alterations and Updates 17 09-27-2016 07:07 PM
Compact juniors: tape: vertical belly band Kent I Problem Solving | Owners Helping Owners 12 11-25-2008 01:05 AM
Boler Belly Band Sealer Dave Mc Problem Solving | Owners Helping Owners 7 05-09-2008 05:49 AM
HOW DO I RE-ATTACH BELLY BAND Mary Lynn K. Problem Solving | Owners Helping Owners 19 05-30-2006 05:38 PM
Belly Band Leaking? Isaac M Problem Solving | Owners Helping Owners 23 05-17-2006 10:06 AM
» Trailer Showcase
TBD
yamasaki
Bronco
Tom H. AZ
