I'm looking for shelving/storage ideas to replace the front end/table area - Fiberglass RV
Go Back   Fiberglass RV > Maintenance | Restoration | Modifications | Problem Solving > Modifications, Alterations and Updates
Click Here to Login
Old 09-23-2022, 06:45 AM   #1
Trailer: 1985 Burro
Maine
Hi, I'm working on a 13ft Burro camper that I will be fulltiming in.
I'm looking for ideas on how to create storage/shelving thats off the ground in the front half of the camper where a table or bunk beds usually are. (Mine is gutted)
All ideas/photos are much appreciated!
Kblue is offline   Reply With Quote
Old 09-23-2022, 10:35 AM   #2
Name: You can't call me Al
Trailer: SOLD: 1977 Scamp 13'
Massachusetts
We removed the front bunk and stored all the parts so we can rebuild it if the next owner wants to use them.
I built a countertop across a little more then half the space and installed two HUGE coolers so we can camp for a week or more. (If we can get ice to refresh the coolers)
It's all basically 1/2" plywood, primer, paint and metal brackets.
I plan on adding a string mesh to the right-side to keep things from flying out as we travel.
It gives us a lot more room for food prep, dish drying and storing things as we're camping.
AlanKilian is offline   Reply With Quote
Old 09-23-2022, 10:39 AM   #3
Alf S.'s Avatar
Hi: Kblue... IKEA is a friend of mine. They're #1 for small space storage!!!
Old 09-23-2022, 10:51 AM   #4
Trailer: 1985 Burro
Maine
Oh that looks great! Giving yourself more counter space is smart- and I was wondering where I was going to keep a cooler.
I guess I should also ask how do you install without putting screws into the fiberglass siding?
Old 09-23-2022, 11:06 AM   #5
Massachusetts
The lower shelf is screwed-in to the wood support structure that was used to hold the lower fiberglass part of the seat all the way around. That holds it in really well.
The upper part under the countertop is bolted to the upper wooden part that used to support the upper bunk in two places. It's also bolted to the steel support bar at the left-edge of the door opening with a 90-degree metal bracket.
So no screws/bolts through the fiberglass at all.
Old 09-24-2022, 04:27 AM   #6
Trailer: Boler 13 ft
Cooler looks great there ---- but---- I have the same cooler, empty it's not too bad but put ice and food in it, I can hardly lift the thing to get it in my SUV.
Is this cooler on a pull out tray?
Old 09-24-2022, 07:58 AM   #7
Massachusetts
Yes the center cooler is on a structure with two heavy-duty drawer slides so it never leaves the camper.
After learning my lesson from the first test drive full of water, I now have steel locking pins that keep it from breaking the 3D-printed clips I made, rolling out and jumping up and down on the drawer slides, bending them out of shape. (That cost me $60)
I also made some tubes that go outside the camper through the front floor and end in valves so I can drain the water from the coolers without taking them out of the camper.
So, they never leave and I never have to left them, full or empty.
Old 09-24-2022, 10:30 AM   #8
Trailer: 1985 Burro
Maine
What cooler is it?
Old 09-24-2022, 11:26 AM   #9
Massachusetts
What cooler is it?
Mine were Nurxiovo brand 75 quart coolers from Amazon, but there are at least 3 other identical versions with different branding. Mine were US$250 each
This one looks pretty similar.
https://www.amazon.com/EchoSmile-Rot...f-a2c47c48c32f
vin
Shelving for storage closet DaveWI Modifications, Alterations and Updates 5 10-29-2020 08:18 PM
Ideas for front seating area mossygal Problem Solving | Owners Helping Owners 6 03-24-2020 05:19 PM
More Storage: Shelving and back splash basket junglejim83 Modifications, Alterations and Updates 5 10-18-2017 09:45 AM
Storage, Storage, and Storage Legacy Posts Problem Solving | Owners Helping Owners 18 11-20-2002 10:43 AM
Storage, Storage, and Storage Modifications, Alterations and Updates 0 01-01-1970 12:00 AM
