Installing a rear view/back up camera - Page 2 - Fiberglass RV
Old 06-18-2021, 08:42 AM   #21
Trailer: 1973 Trillium 1300
End result
Alright so here’s where we ended up. It’s not pretty but does the trick! Also have the flex mount one installed to test it as well. Will see which wins the day
D18C595F-4CA9-4B22-AA2F-C44E6557B836.jpg   8C3E12FF-449D-4380-B0C5-8C26FDD7D899.jpg
Alex T is offline   Reply With Quote
Old 06-18-2021, 10:01 AM   #22
Trailer: Boler American
Im sure there are other brands for cheaper. I just hope that installers poo-pooing suction cups are not thinking of the old kind used to hold up a sign! These guys are used to put bicycles on cars, i think they can probably handle a camera as long as the surface you are using is fairly smooth. With all that said, i am NOT using this product currently, but i wouldnt hesitate to
https://www.seasucker.com/collections/gopro-camera
Cesar is offline   Reply With Quote
Old 07-06-2021, 10:49 PM   #23
Markz's Avatar
I installed rear Camera in the center on my rear rack. The Camera is powered off of a wifi transmitter that's connected to the driving lights. This way I can observe traffic behind the camper while driving on an old cellphone via a wifi connection. I also mount the cellphone to my rearview mirror while the camper is connected. This way its intuitive. I also switched out the mini antenna from the transmitter for an remote unit mounted to the front tongue for better reception.
Good luck. Click image for larger version
ID:	141886Click image for larger version
ID:	141887Click image for larger version
ID:	141888Click image for larger version
Markz is offline   Reply With Quote
Old 07-07-2021, 09:17 AM   #24
Trailer: Scamp 1995 19'
Originally Posted by CPW View Post
... These cameras have infrared capabilities for “night vision” and infrared rays bouncing off the glass render the camera useless for backing into a dark campsite. ....
Good to keep in mind. I would like to place 4 of these pointing in all directions, with motion sensor ability to keep track of people around me. Keep an eye on my truck bed or my solar panels etc.
Especially when i am out of the RV for awhile. And of course night vision is a big plus.
I had a camera many years ago watching a bird's nest in the carport under the eve of my house for my kid's benefit. It was cool to watch the parents fly in and feed the little ones, then fly back out for more bugs. A lot of work I can tell you that.
And then we watched a snake which had climbed up the inside of the brick pillar and snatched a little bird. Traumatizing for the kids. Life's lessons...
I moved the nest, put it in a hanging plant basket and moved it out to a hanger in the carport ceiling. It took a looooong time for the parents to notice their kids chirping away in hunger and frustration just 6 feet away from where the nest used to be. They eventually did. And no more snakes.
jwcolby123 is offline   Reply With Quote
Old 07-08-2021, 06:30 AM   #25
Trailer: 2014 13' Scamp -standard w/ front bunk
Vermont
Originally Posted by David B. View Post
In our Scamp I mounted the camera inside pointing out the rear window. Power was easily obtained from a 12 volt outlet.
Best of luck.
Dave & Paula
I also wanted to avoid adding holes to the shell and mounted a camera inside just as Dave and Paula. I fabricated a simple clip that mounts on the rear sliding window frame so it is easy to remove the camera when we're at the campsite. Works well for us.
WDavidG is offline   Reply With Quote
Old 07-09-2021, 02:15 PM   #26
Trailer: In the market
Montana
Costco had a wireless backup camera that was great. The camera mounts to your license plate holder. The camera is solar powered, and it also has a screen that is usb powered. No wires to run, easy connection. I like mine a lot.
Monster Hair is offline   Reply With Quote
Placement of rear view / backup camera? Ottoscamp Towing, Hitching, Axles and Running Gear 43 05-10-2019 06:03 PM
A really, really, really good rear view camera. Nik Modifications, Alterations and Updates 34 11-22-2017 01:56 PM
Back-Up/Rear View Wireless Camera Reliability C&G in FL Problem Solving | Owners Helping Owners 14 05-06-2017 09:08 AM
Wireless Rear View Camera Victor Benz Towing, Hitching, Axles and Running Gear 21 10-22-2016 08:50 AM
Rear View Camera Question C&G in FL Problem Solving | Owners Helping Owners 32 12-20-2014 04:24 PM
