Installing Anchor or Cargo Tie Down Points Inside - Screw Length? - Fiberglass RV
Go Back   Fiberglass RV > Maintenance | Restoration | Modifications | Problem Solving > Modifications, Alterations and Updates
Click Here to Login
Old 08-01-2020, 06:39 PM   #1
Trailer: BigFoot
I purchased these anchor/cargo tie down points . Will be installing them in inside my 2004 Bigfoot 17CB to hold various items in place while traveling. I have had similar items in a past trailer and they worked well.
Is there a suggested screw length I should use when installing them on the floor? They didn't come with any screws and while I have plenty of screws loose I need to know about what length I should use. Assuming there is a wood subfloor before the fiberglass?
Thanks
Eric
DesertBF is offline   Reply With Quote
Old 08-03-2020, 03:22 PM   #2
Berthaduniverse's Avatar
Couple points to consider.
1) if the hole and hanger are for light weight materials like a cargo net to hold a clothing bag, then find the largest diameter screw that doesn't pierce through the plywood. Maybe a 3/4 in long #10 or #12 hex head or Phillips button head wood screw.
2) if you want to hold down a generator or ice chest, then make sure you are using something like a 1/4-20 bolt and nut with a good sized fender washer backing it up. Be careful when drilling, as there can be plumbing, wiring, or metal structural members under the plywood you don't want to drill into.
Berthaduniverse is offline   Reply With Quote
Old 08-07-2020, 10:59 AM   #3
Trailer: BigFoot
Thank you for the ideas. I think the washer idea is a good one if I can find safe locations to drill. I will crawl under and check out my options.
Thanks
Eric
Old 09-27-2020, 01:41 PM   #4
Trailer: Coleman Destiny Cedar
Thanks
Eric
Come on Eric, don't we all have a few loose screws, i certainly do.
😉Neal😉
Nealster is offline   Reply With Quote
Screw holes. How do I repair the old screw holes around the Window. BeckyK Care and Feeding of Molded Fiberglass Trailers 5 07-17-2017 07:03 PM
Robertson Head Screw (Square Drive Screw) Huck Problem Solving | Owners Helping Owners 45 06-01-2015 12:46 AM
Dog Leash Up/Anchor Point In Trailer While Camping/Sleeping: What do you do? CampyTime Modifications, Alterations and Updates 64 10-28-2014 07:02 PM
How do you tie things down inside the camper lpk49 Modifications, Alterations and Updates 40 05-25-2013 11:00 PM
A Home Brew Tie Down System for the Pickup Raz Problem Solving | Owners Helping Owners 6 04-25-2013 07:50 AM
