Installing extra batter in Casita SD - Fiberglass RV
Old 04-04-2024, 10:52 AM   #1
Trailer: Casita SD 16
Maine
Hello,
I own a 2006 Casita SD 16' in which I would like to install another AGM battery. If you know Casitas, you will understand my problem finding a place to put this battery.
I am considering attaching it in a battery box to the front of the frame. The problem is the length of cable between the two batteries. I read that the shorter the distance the better so this length may be too long.
I have considered other methods like placing beneath the bed/dinette but it is a second choice. I would appreciate other views of this problem.
Also, I installed a Parallax Power Supply 081-7155-000 Replacement Power in the camper that is rated at 55W. Is this considered a safe wattage for the Casita?
Thanks for any light you can shed on these questions
macbethdt is offline   Reply With Quote
Old 04-04-2024, 11:43 AM   #2
ShelbyM's Avatar
Trailer: Casita SD
Not meaning to derail your thread but have you considered replacing your AGM with Li? You'd get close to double the usable Ah in the same space w/o having to locate and wire a second battery.
If the shoe fits...
Old 04-04-2024, 12:06 PM   #3
Maine
Thanks, that's an interesting idea but with two fairly new agm batteries and a new non-compatible Li converter, it would be costly in time and money.
Old 04-04-2024, 05:25 PM   #4
Raspy's Avatar
Trailer: Roamer 1
Smith Valley, Nevada
If you are going to install another 12 volt battery alongside the existing 12 volt battery, or two new 12 volt batteries, they will be wired in parallel. Just connect the plus wire to one bat and the minus wire to the other bat. This compensates for the extra cables and makes the batteries charge equally. An extra 2-3 feet of wire is not going to make any difference. A little bit more wire is less of a problem than finding a whole new place for them or possibly running much longer wires to a some new location. Also, lead acid bats should always have ventilation, so the tongue mount has some advantage. However, installing one lithium battery, instead of the existing lead acid, can give you nearly twice the usable power. And lithiums only weigh about 2/3 what a lead acid weighs. There are a couple of downsides to lithiums, so do a little research before deciding to switch.
Old 04-12-2024, 07:38 AM   #5
Trailer: Currently Looking
Casita extra battery
My question is if this is for emergency backup or if you regularly think you will use up the juice of 2 batteries?
If it is more of a "just in case" situation, then my solution is to just keep a fully charged extra battery on hand. I keep mine under the bunk and it is slightly smaller and lighter. Do you have a battery sliding tray? That makes it easier to swap in those few instances. I also have a loose Lithium Ion power box from Energizer that I love.
If not and you wish to increase your battery bank then yes running long wires can be an issue depending on the load. That all being said you need to know what the standards are. Even then I suggest some caveats:
1. The power controller will be charging 2 batteries, and so it needs to be sized accordingly. You will need to contact a battery power supplier for that information.
2. all your batteries need to match. So if you go to AGM then both batteries should be AGM. Also I know from experience that if the charging on the AGM is not very controlled (the charging voltage spectrum is narrow), then you can ruin the AGM very easily. I plugged in a voltage meter in a 12V plug to monitor charging voltage. Dont quote me but I think it needs to be less than 14.4V and mine runs at 13.7 when charging. Also undercharging or overdrawing an AGM is apparently a problem.
3. Situation 2 does not apply if you just swap out the battery. So in fact I can use my energizer to power up the whole cabin if need be. Actually that might be my next plan Why did I not think of that before!
Good luck.
bjarki is offline   Reply With Quote
Old 04-12-2024, 07:52 AM   #6
ShelbyM's Avatar
Trailer: Casita SD
Good luck.
Is this a Li battery you keep under the bunk? Which model Casita do you have?
If the shoe fits...
Old 04-12-2024, 10:31 AM   #7
Lithium Ion
Yes I keep a Lithium Ion charge bank from Energizer. The beauty is that I can use it for other things and if you plug it in as a battery then it has up to 120Watts of power.
The Casita is a 2023 Dl and the layout is the Independence
Old 04-12-2024, 10:34 AM   #8
Lithium Ion
Yes I keep a Lithium Ion charge bank from Energizer. The beauty is that I can use it for other things and if you plug it in as a battery then it has up to 500 watts of power.
Look for Energizer Arc 3 or Arc5
Old 04-12-2024, 01:14 PM   #9
Lithium Ion
Old 06-02-2024, 01:26 PM   #10
Trailer: casita independence deluxe 2019
ready to replace casita independence battery, raspy mentioned downsides to lithium battery please advise
garysharris is offline   Reply With Quote
Old 06-02-2024, 03:10 PM   #11
Raspy's Avatar
Trailer: Roamer 1
The downsides to lithium batteries are as follows: They cannot be charged below an internal temp of about 32 degrees because they have an internal Battery Monitor that manages them and will shut them down when too cold. Some of them have internal heaters, but those heaters use the battery power to make heat, and mounted outside, it can be a significant amount of power used. So putting them out on the tongue means you may have some problems in cold weather. Inside, they can be kept warmer, usually with furnace heat. Mounting batteries out on the tongue is not a good idea anymore as lithiums do not need ventilation and they must be kept warmer than 32 degrees to continue working. Other problems are: They cost more initially, than lead batteries. They will need a new charging program to charge them correctly. But these problems are outweighed by their performance and light weight. Lithiums are so much better than lead batteries.
casita
Best place to mount extra AGM battery on Casita SD 16 macbethdt Electrical | Charging, Systems, Solar and Generators 0 08-10-2023 12:08 PM
When to Replce our Casita Batter? Jude Care and Feeding of Molded Fiberglass Trailers 5 09-17-2021 07:50 PM
Extra Casita Spirit Cushions - earth tones L Schmidt Classified Archives 0 09-23-2009 01:16 PM
Extra things Legacy Posts Care and Feeding of Molded Fiberglass Trailers 32 01-08-2003 09:05 PM
