I have a 96
Casita Spirit. In this model, the door is curved which adds some challenges. A previous owner removed the carpet and put in cork, which obviously did not work well since it just soaked up the moisture. I am replacing it with a vinyl that has a 1/2 pad similar to
Casita carpet but is a bit easier to install, cheaper and I’m hoping will be easier to clean and not absorb smells. But the door is the challenge. Because it is rounded and not a flat surface the vinyl will not go on it well, go around the handle or look right at the edges. I’m open to using a different material but am hoping someone has a suggestion on how to approach this. I’ve attached pics to show the door and the vinyl. Thank you in advance!
