Interior walls of 1975 Trillium? - Fiberglass RV
Old 09-14-2022, 12:35 PM   #1
Trailer: 1975 Trillium
HI! We purchased a 1975 Trillium a few years ago, that was partially gutted, and we are finally getting around to refurbishing it.
The interior walls are down to the fiberglass, and I am totally confused as to what to put on the walls... They were stripped when we purchased it, so I did not see what was on them prior.
I tried to look for a thread here to help me understand what to put on the interior walls, but no luck. I am probably not searching for the right term.
Can someone help me?
Thanks in advance,
Kimm
KimmD is offline   Reply With Quote
Old 09-14-2022, 01:32 PM   #2
David Tilston's Avatar
Thanks in advance,
Kimm
Kimm, Originally there would have been a product called Ensolite. This was a black closed cell foam with a white(ish) vinyl outer layer. While the black foam is still available, I have yet to find it with the vinyl layer. What several fibreglass trailer vendors use is Reflectex https://www.homedepot.ca/product/ref...ion/1000167795 covered in a marine head liner, which is just a stretchy waterproof fabric.
Old 09-14-2022, 01:43 PM   #3
Thanks David. That makes sense because there was some pieces of the black foam still on the walls that I have removed.
That is exactly what I was going to put on the walls, but I wasn't sure if there was something easier?
Do you know if the Reflectex has an adhesive, or do I install it with rubber cement?
Then would I attach the fabric on the Reflectex with rubber cement as well?
Thank you!
Old 09-14-2022, 04:42 PM   #4
Thank you!
Typically contact cement is used for both the Reflectex and head liner. The glue you use should be rated for a fairly high temperature. It gets hot under the sun.
Old 09-16-2022, 08:50 AM   #5
Okay awesome. Thank you so much for your help!
Old 09-23-2022, 10:13 PM   #6
Glue to use on Fiberglass (FRP)
Use Fiberglass Resin / harder mix as it’s the same as the Fiberglass itself
It hardens like a rock holding whatever you want to the wall.
I always test the items that you may want to attach as the chemical reaction may not suitable.
Hope this helps.
Ray11
Ray11 is offline   Reply With Quote
Old 09-23-2022, 11:31 PM   #7
John in Santa Cruz's Avatar
Mid Left Coast
If I was completely restoring the interior of a stripped FG shell, I'd consider using the sort of aircraft/marine headliner Escape uses, possibly on top of a couple layers of thinsulate and/or reflectix. It has a textured off white interior, easy to wipe and clean, and is bonded to a thin layer of firm foam, it can be glued or stretched over a surface. Its way nicer than the 'shag carpet' liner of my old Casita. Its also a lot quieter, and much better insulating as well as completely dark inside during the day
Old 11-17-2022, 09:35 AM   #8
Hope this helps.
Ray11
Okay, thank you!
Old 11-17-2022, 09:40 AM   #9
Thanks John, I will definitely check that out!
trillium
Perris Pacer: Fixing interior walls Eve V. Care and Feeding of Molded Fiberglass Trailers 7 09-24-2016 02:13 AM
Trillium interior walls hixon Modifications, Alterations and Updates 5 04-27-2015 10:07 AM
Success with Int paint walls,countertops,Cabinets, Carpet for floors. Walls, too? Gigi Problem Solving | Owners Helping Owners 2 08-31-2012 11:13 AM
Another approach to finishing interior walls Brian Scott Problem Solving | Owners Helping Owners 12 03-08-2008 06:02 PM
Interior Closet Walls Legacy Posts Problem Solving | Owners Helping Owners 5 08-09-2003 07:08 AM
