Karin's Campster Renovation - Page 20 - Fiberglass RV
Old 09-24-2020, 03:50 AM   #381
CindyL's Avatar
Trailer: 16 ft U-Haul VT
Could you post more inside pix? Maybe I missed them, but I could not find images of the cupboards after you added the mesh inserts.
Thanks. I have been so impressed with the work you did.
CindyL
1988 Bigfoot Silver Cloud, "The Egg Carton"
CindyL is offline   Reply With Quote
Old 09-24-2020, 08:30 PM   #382
Trailer: Trails West
CindyL
there are no photos because I have not yet made the cabinet doors. It will be a few months yet before I get around to that. Next up is to get more of the wiring installed. It would be way too hard to get inside the cabinets to hook up wiring if the doors were installed.
Old 10-26-2020, 04:54 PM   #383
popup top custom cross bracing
Name:	<a title=campster x brace.jpg Views: 23 Size: 194.8 KB ID: 138248" style="margin: 2px" />
Heads up alert, Campster popup tops are not all made exactly the same way for every year so my dimension might very well not work at all for your Campster if you want to make cross braces for yours. Also I added a thick bulb seal to the bottom of my top which has a flange on it whereas other years of Campster do not have a flange on the edge. So it is highly unlikely that you can exactly copy what I have done using the dimensions I am stating. But at least my custom modification will give you an idea how to approach this project and put your own spin on it.
It is about time I showed the cross bracing I installed in the narrow ends of the canvas top this summer. My top had taken a decided lean to one side which bugged me a lot plus I plan to be full time on the road and want to leave the top up even on windy days. The new cross braces are a real success, the top is now very stable and does not move side to side even in strong winds. Of course you absolutely do have to take the braces out, lower the top and clamp it down for travel.
Because I removed the thin metal trim and put some 3/4" thick wood trim around the inside edges of my popup top it was a pretty easy job to add cross bracing. I made my upper trim 1-1/2" wide and my lower trim is 2-38" wide. That allows my top to sit down flush but still have a gap between the wood frame for the canvas to come inside the interior when the top is lowered. My hold downs are not the original ones and they too are installed through and into those wood trim pieces. I showed those hold downs previously.
The cross brace pieces are 1/8" thick by 3/4" wide T 6061 aluminum bar stock. Not that difficult to find in hardware store sources. I wanted all four of the bars to be the same length. So first I had to figure out the center point of the upper edge and the lower edge then measure over the same distance to the sides, make a mark that would become the center of a drilled hole in the wood into which I would install an 8-24 threaded insert. Those are also easy to find in a hardware store but a little tricky to get them going into the wood in really straight unless you have a special tool for it which I did not bring along with me.
Next you make sure the top is fully extended and then you have to make sure that the centerline on the top and the bottom are in line with each other and side to side the top must be squared up true. Easier to do with two people or the assistance of some clamps and boards. It has to be squared up at 90 degress so that you can measure the diagonal length for the braces from the center of the hole on the top to the center of the hole on the bottom. That and a little extra length at the ends for edge margin around the holes gives you the overall length to make each of the 4 cross brace bars.
My 4 braces are 27-1/2" in length between the center point of the holes that secure them I don't know if all of the popup openings remained the same over the 3 years of production but that might be possible. I would hope it did but truly don't know that for sure. You need to make your own measurements and not just use mine because of all the variations I have such as having installed that wood trim inside the opening.
My braces are secured into the threaded inserts using 8/24 socket cap machine screws. The hardware stores sell caps with knurled edges that you can push onto the socket cap machine screws. Those caps mean you don't need any tools to remove and reinstall the braces. If you have measured and drilled carefully all four braces will be interchangeable. If the socket cap screws are a little too long you can trim them shorter. I trimmed mine using a fiber reinforced cutoff wheel in my Dremel Motor.
Old 11-14-2020, 01:10 AM   #384
I will soon have some more renovation photos to post but not for another week or two. Just finished up installing my diesel fueled cooktop/heater that I purchased a long time ago. Made a hot cup of mocha with it to toast getting that task finally check off my list.
In the morning I will begin my migration out of WA state, down highway 101 to California then over to Arizona for the winter. Because of the Covid situation I won't be doing very much sightseeing on this trip other than taking a walk or two to break up the long days of driving.
I don't know if there will be a fiberglass rally in Quartzsite this year but no doubt some of the regulars from this forum will still show up in the area. You will most certainly notice my red and black trailer and Honda Element pair. They stand out like bright red birds among a flock of white gulls. Say hello if you see me outside enjoying the sunshine.
Old 11-14-2020, 02:03 AM   #385
Good luck with your travels. I hope you will continue posting, I look forward to reading them.
Wash your hands!
ReneeN is offline   Reply With Quote
Old 07-22-2022, 09:24 AM   #386
campster custom cabinets
I am getting very close to finishing my custom layout cabinetry. Here is a sneak peak, drivers side looking towards the rear. I had just put on the poplar wood trim around the recharging outlet station. Still waiting on some parts to arrive from Amazon before I can try to find a friend to help me glue up the headliner.
Name:	end of kitchen cabinets.jpg
I hope everyone is enjoying their summertime camping. I am having a nice time camping full time. I am in Northern Arizona for the summer with other friends camped nearby.
Old 07-22-2022, 09:56 AM   #387
Looks wonderful! Can't wait to see the whole thing. Northern Arizona has been nice this year, with reasonably reliable monsoon rains. There's some great camping and boondocking over here in the White Mountains as well (Heber, Show Low, Pinetop, Springerville, Alpine). Enjoy!
Old 07-22-2022, 04:10 PM   #388
EllPea in CA's Avatar
Trailer: 1989 Lil Bigfoot
CA
Attachment 146636
That is a beautiful cabinet! I'm guessing the temperatures are cooler in the northern part of Arizona.
Best,
EllPea in CA
EllPea in CA is offline   Reply With Quote
campster
Renovation/Fix-Up... Easier or Harder than you thought? Buck62 General Chat 33 10-09-2020 10:43 AM
Lite House Renovation Bill&Pat General Chat 13 08-25-2012 06:28 PM
1970 Campster Renovation Chris McGurk Modifications, Alterations and Updates 4 06-03-2012 03:24 AM
1973 Compact Junior Renovation Barb Egeland Problem Solving | Owners Helping Owners 3 01-10-2006 04:25 PM
Closet Renovation Legacy Posts Modifications, Alterations and Updates 8 06-18-2003 03:14 PM
Copyright ©2000 - 2023, vBulletin Solutions Inc.
