LED Marker lights - Fiberglass RV
Old 07-29-2013, 11:41 AM   #1
Trailer: '79 Boler 1700RGH
LED Marker lights
Seven Reds and four Ambers..I got em on sale a while ago when I broke one of my factory ones out on a tree <doh>
4 x 2-1/16 in. LED Catseye Clearance/Marker Light | Princess Auto
Also replaced the staples (not)holding my drawers under my fridge up with screws+glue..mmmm working drawers.
Boleroleroleroleroleroleroler
Kinslayer is offline   Reply With Quote
Old 07-29-2013, 11:57 AM   #2
So on that vein i've been looking for a sealed LED tail light that I can mount inside the factory covers to retain a factory look. I tried using LED bulbs but to be honest they suck. I think they are designed for rear facing sockets and simply are not bright enough.. I think the best bet would be a 6 inch round if it would fit but it's tough.
Anyone do this? what did they use?
Old 07-29-2013, 03:36 PM   #3
pugslyyy's Avatar
Trailer: Bigfoot
I just did this on my Bigfoot - 7 amber and 5 red. Makes a huge difference in appearance, IMHO.
I used Blazers.
Amazon.com: Blazer C539A Amber LED Double Bullseye Side Marker Light-1 each: Automotive
pugslyyy is offline   Reply With Quote
Old 07-29-2013, 05:28 PM   #4
Brian B-P's Avatar
The markers look good, Don. I bought the same lights, but have yet to install them. They're not the same shape as the originals, but I think they suit the trailer better. Do you have daylight pictures to show the look?
I was hoping they would fit - thanks for blazing that trail!
How did you mount them: self-tapping screws into new holes? Any wiring tips?
Old 07-29-2013, 05:51 PM   #5
I'll take a some pics tonight.
I re-used one hole on each light, and had to drill one new one. The wiring on these markers is designed to be connected behind but that really makes it tough/impossible.. So on the wire wire I cut off about 2.5 inches (including the round metal connector) and used the insides of butt connectors to connect everything. Yes, the 'inside'.. I used a punch to knock out the metal centers from red connectors. most of the markers have two white and two green wires (white to white & black to green, FYI). Since you're using two wires jammed into one side of the butt connector you gotta splay it apart a bit with a razor blade and flat head screwdriver..
Anyway, also, beyond that, I had to pull the wires through to the front of the marker light, and for the boler half of the wiring, I had to drill a decent size hole (3/8's is sufficient in every case) below the LED module on the inside, far right hand side immediately below the last LED in the row. (i'll post a pic later when I get home).. there, it lines up with the hole in the fibreglass and the marker mounts flush.
screw it on and clamp it shut with your crimpers. I used brush on electrical tape as an insulator and silicone to seal the wire hole.
They look absolutely identical to the originals, but clean and bright and all working.
*edit, ah yes, I used butyl tape to seal/stick em to the boler.
Old 07-29-2013, 06:18 PM   #6
Brian B-P's Avatar
Thanks Don. Your description makes sense but I still look forward to the wiring photo (no rush of course).
I guess our trailers came with different lights... my originals are a different shape: #99 Clearance / Side Markers - Bargman
Old 07-29-2013, 10:38 PM   #7
Ya..the ones I had on there don't look like those, that's for sure.
Here are the pics
Old 07-29-2013, 10:49 PM   #8
Brian B-P's Avatar
Here are the pics
Nice and clear!
light, lights
Brake Lights, Turn signal lights, marker lights, oh my! glamourpets Problem Solving | Owners Helping Owners 19 01-03-2013 10:10 AM
Marker lights on Deb & Chuck Problem Solving | Owners Helping Owners 47 10-23-2012 01:40 PM
LED trailer lights / Non LED lights on tow vehicle Kevin K General Chat 20 11-24-2010 12:05 PM
