06-09-2020, 10:03 AM
Trailer: 1980 Trillium 4500
LED replacement bulbs for boondocking
Hi fellow campers. Looking for interior LED replacement bulbs to be energy efficient & reduce battery drain while boondocking.
We like the warm glow our current incandescent bulbs throw so around 3,000 lumens. 194 style bulbs. Checked Amazon and not finding it. Appreciate any suggestions.
Thanks
06-09-2020, 10:41 AM
LED replacement for 1156 two-pin halogen
You might want to consider the following if you are looking to replace a two pin halogen (1156). Good communication with seller.
https://www.ebay.com/itm/10X-Warm-Wh...53.m2749.l2649
06-09-2020, 10:42 AM
Led
Originally Posted by Davo
I'm looking for LED replacement bulbs to be more energy efficient & reduce battery drain while boondocking. We like the warm glow our current incandescent bulbs throw so no more than 3,000 lumens. Has anyone found a good product? Appreciate any suggestions.
Try Amazon
06-09-2020, 10:46 AM
Just posted this for another message. This seems to be a good replacement for the 1156/two-pin halogen bulb. Seller experience was good. Needed seven for our 16' scamp so ordered a couple extra. No long term results to report.
06-09-2020, 11:23 AM
Thanks
3,000 Lumens is a whole lot of light! Lumens are light output, not color temperature.
An old style incandescent bulb is approx 2,700 K (degrees Kelvin).
Bright white is about 3,000 K
Daylight bulbs are about 4,000K
Other daylight bulbs can be found at 5,000K.
Basically, the higher the color temperature the more "blue" the light appears.
I think you are going to be happiest with the lower color temperature, 2,700-3,000K
Remember, Lumens are light energy output. Color temperature in K is the "color"
06-09-2020, 11:31 AM
Led
Originally Posted by Brentsdeal
Try Amazon
You can put a jell in the fixtures, it is a colored film we use in the movie business to change the color of lights, I used it in all of my lights in my trailer to get rid of the obnoxious blue led lighting that the factory led out out, Ill try to post the exact name of the jell you need,
06-09-2020, 12:07 PM
06-09-2020, 12:12 PM
Led
Originally Posted by Dpschu
Good job!!!
06-09-2020, 12:44 PM
Thanks
Due you mean 3000K color temperature. 3000Lumens is very very bright.
06-09-2020, 01:12 PM
Trailer: Sasquatch
Montana
I use these. Not cheap, but they've worked well for me, and are similar to incandescent.
06-14-2020, 01:19 PM
Trailer: Scamp 2017 16-ft SD / FB
LED Replacement Bulbs - Interior, Warm Glow?
Attached is info on LED Bulbs and Kelvin scale. I like the brighter lights over the dinning table. But each to his own
Henry
Houston TX
Scamp 2017 16ft FB/SD
06-14-2020, 04:58 PM
Mid Left Coast
if your trailer uses 1156 (bayonet mount older-style car tail light bulbs), I've had very good luck with the ones from www.superbrightled.com ... My Casita has nothing but.
I've also used their bulbs in other form factors, again, very good results.
edit; I just saw that you said 194 style bulbs, dunno how i missed that. here, try a few of these...
warm 3000k, 85 lumens, 360 degree pattern, voltage regulated...
https://www.superbrightleds.com/more...tributes/10831
and IF your fixture will take them, these are 170 lumen, with all the light coming out one side, 3000K, also regulated
https://www.superbrightleds.com/more...0-lumens/2804/
I mention voltage regulation, as the voltages on our trailers tend to meander around quite a bit depending on whether you are on the power converter, or solar, vs strictly on your battery. unregulated LEDs change brightness with voltage, and can flicker and stuff, while regulated bulbs will be a constant brightness anywhere in the 10-30VDC range.
06-14-2020, 08:23 PM
Originally Posted by John in Santa Cruz
My Scamp also uses only bulbs from them. Some people have been critical of me for spending more for their products, but in almost every case I have found that I got my money's worth. If nothing else, I recommend going to their website for technical information. That information is also part of the value that I have paid for.
06-17-2020, 11:32 AM
Trailer: Former Scamp 13, Former Airstream 16
Connecticut
For the warm glow, you want a color temperature for the bulb that does not exceed 2800K.
I would highly recommend Dan Brown at www.LED4RV.com
All the bulbs I have purchased from him work perfectly and perform exactly as I want them to.
Excellent selection and customer service.
Mike
06-17-2020, 03:04 PM
Trailer: Scamp 19' 5th Wheel
TX
I agree wit most. Amazon is best place to go for LED bulbs.
Yank.
06-17-2020, 03:13 PM
Yank.
Yup. Bezos needs the money. He's not a trillionaire yet.
06-18-2020, 09:00 PM
Most LED bulbs you buy are not the kelvin they claim to be. I use only M4Products lamps as I find them to be spot on. I use the Natural white which is neither yellowish nor bluish, just a pure white. Old eyes need all the help they can get.
https://m4products.com/
I have bought some 194 replacements for marker lights on a trailer from superbrightleds and found them to be quality, but for other lighting needs, i stick with M4 because of the accuracy of color and quality of the product.
Charles
'03 Ram 2500 CTD, 5.9HO PacBrake six speed std cab long bed Leer top and 2008 Bigfoot 25B21RB.. Previously, 2008 Thor Freedom Spirit 180, SOLD! 2007 Winnebago View 23H Motorhome, SOLD!
08-11-2020, 09:31 PM
Trailer: Scamp Deluxe 16ft
Alabama
Replacing bulbs with LED's
I'll dig this one back up and some thread drifting, I changed out all of my Scamp bulbs but tail lights to LED's a years back, then I started having them burn out /fail. Finally I just replaced them with boat / RV LED lights, I would have saved money just doing that the first time. The "reading" light may still have a LED bulb but I have replaced it quite a few times even due to it burning out. When did I ordered 6 single LED lights and a double LED light it was less to buy 6 than the 4 needed.
The 120v light quit above the side dining area, I installed a outlet and a plug-in 120v LED bar light replacing the florescent light. I'm sure the LED's have saved me a lot of battery and money over the time installed in electricity.
08-14-2020, 01:21 PM
Thank you for posting for me... LOL!
