Originally Posted by Paul O.
I second that.
Also you can find the leak, or get close by just sniffing around. The more information you have for the repairman, the better. Soapy water is definitely the way to find where it is exactly. Good luck!
I third that. and if you smell it after turning on EITHER the range OR the heater, than they BOTH need repairing.
now, if you smelled it when you turn on the tank valve, then its a system problem, probably a leak in one or another fitting.
question, if you
light the range, do you get a clean blue flame, or a rough yellow one? a rough yellow flame would mean too much gas, probably due to either a plugged air intake on the stove's air mixer, OR overly high propane pressure suggesting the propane regulator at the tank is bad.
