Lots of scamp modifications - Page 2 - Fiberglass RV
Old 06-16-2003, 08:21 AM   #21
Too, too cute. That door and those hinges are a crowning touch.
Good job! :)
Old 06-16-2003, 11:11 AM   #22
Mods
I think that since you painted all those flowers with shadows etc, you
can also do the rocks very well, without any help. That is a very unique idea to paint it in a cottage style. Very nice, neat and tidy looking
"Art Project". "you know you can do it!!"
Willma
Old 06-16-2003, 07:35 PM   #23
redone rocks
Thanks Willma, for the encouraging words...
I've already tried numerous times to get rock shading... I must be missing some trick...
If you were to see the flowers up close you wouldn't necessarily think they are well done. The shadows there is just a black sharpie marker.
A marker doesn't work well for rock shading, and my brush strokes are wrong.
I may just leave it as is. It's better than anything else I've been able to do.
Old 06-17-2003, 08:24 AM   #24
Rock issues
I have had some luck in the past with using a pallet with two or three colors on it. Perhaps try working on a piece of scrap wood so you can see the effects. My technique usually involves putting three coordinating colors (say light tan, dark tan and a light brown) close to each other on the pallet, then using a sea sponge to dip a little of each. You want the colors to run together but not completely mix. Then dab on the "rock." Get a little more and dab on some more. Use more of the darker colors on the bottom and edges of the "rock." Keep your shadows consistent (shadow the same side of adjoining rocks. If you want the ricks to be different colors and textures, then do every fifth rock with one mix of paint. Then go back and do every other fifth rock with a slightly differnt mix, etc.
If you can't find or don't have a sea sponge, you might try a regular kitchen sponge. Gently tear off the edges and take a few pieces out of the middle in an irregular pattern so you don't get straight lines in the paint. In either case, rotate the sponge with each dab so you don't create identical shapes in the rocks.
For coordinating rock colors, you might need to start with one small can of tan, one cream and one brown and mix lighter and darker shades to suit your needs.
Good luck!
Old 06-17-2003, 12:05 PM   #25
Great hints
:ola Dear JR, Those were just the kinds of hints I needed. I was attempting to put one color on at a time. I wasn't getting the blend. Also the sea sponge sounds much better than a brush.
Thanks a million. I will post the results one day.
Old 06-18-2003, 02:58 PM   #26
Glad to help
All those hours I spent watching craft and decorating shows on tv weren't a complete waste. :lol2
A friend of mine is trying to talk me into staying with her until her military husband comes back in November. She is attempting to lure me with the promise of all the cable I can watch. Just what I need, no job and unlimited access to the Learning Channel!!!
Hey, Jana, where's the couch potato watching tv smilie? All I can find is the smilie who lost the remote. :hiding
Old 06-19-2003, 04:09 PM   #27
:wave Love your little cottage. I saw the picture of the dolly mounted on the front of your trailer. How is is mounted? I just bought one from Habour Frieght. It is $49, free shipping, of anyone is interested.
Old 06-19-2003, 05:14 PM   #28
Got mine there too....
:wave :wave
Hello Mary,
I got my dolly at Harbor freight too. There are times I want to move the unit around and the car isn't attached. So I thought best to always have the dolly with the Skimp. (My name for the egg)
Mounting it was easy. I bought a strip of metal, bent a couple of U's from it and welded them to the top of the frame. then I drilled a hole through each U so that I could put a pin through that would hold the dolly axle from lifting out of the U's.
If you do the same but don't want to weld, PLEASE remember that you should NEVER drill into the top or bottom of the frame to put bolts into.
You can however, drill into the sides of the frame without the loss of strength. It is a compression/tension thing. It is prefered though to NOT drill. That is why I welded.
Old 06-26-2003, 03:54 PM   #29
Orginally posted by JR Holland
Sorry it took so long, JR. <img src=http://www.fiberglassrv.com/board/uploads/3efb6b06e2fcbchgtv.GIF/> got the couch potato, but couldn't remember where I was to put it.
Old 07-05-2003, 10:19 PM   #30
water tank
:E I spoke earlier of some of the modifications that I made, one being a new water tank and pump. I thought I'd post a photo of the tank as I should have done earlier.<img src=http://www.fiberglassrv.com/board/uploads/3f07a2105cc84sprayer tank.gif/>
This was a perfect fit under the rear bench, although it took up much of the spece, it gave me 15 gal at up to about a gallon a minute.
It has a pressure sensitive pump that detects the drop in pressure when you open a faucett and starts a pumpin' away. It has even enough pressure to go through my demand water heater and to the sink or shower tap on the outside. Very sturdy tank, well built, and has several good mounting options. I used straps.
All I had to do is to remove the sprayer wand and I had at least 10' of high quality rubber hose to reroute to my sink unit.
I think it is a perfect Scamp addition at a great price.
Old 07-06-2003, 06:58 AM   #31
Hi Tom,
It's me again, pestering you for information about your good ideas. I'm interested in your shower set up. Does your hot water heater require shore power? How do you hook up an outside shower to an inside water tank? Any info appreciated. Thanks.
Old 07-06-2003, 10:24 AM   #32
Not that difficult
Dear Maggie O....
You're not pestering me.
In one of the above photographs you'll see under the galley a white tall thing. It is an Aquastar 38B LP. It is a demand/tankless water heater. It runs off propane and does not require power of any sort. It will heat water for as long as water flows through it. The moment water flow stops, the burners shut down. A pilot light stays lit waiting for water to flow again.
The output goes up to my sink faucet. It also has a "Tee" and valve that goes to another hose that I drilled a hole through the fiberglass body for. that hose terminates at the body with a garden hose fitting that from the outside I can connect a short line to a shower head with an inline valve that I can shut off the flow with.
The reason I have a valve under the galley for this shower tap and another valve on the shower itself is that I want to have a shutoff right at the shower, and when the shower is not connected I can positively shut off the water so I don't get any accidental flow to this outside tap. I guess it will keep strangers from coming along and taking a long shower too.
The Aquastar heater is a little taller than the inside of my galley so I had to lower the floor in the galley with a wooden box enclosure. That way it didn't stick up through my wooden galley top. The only shorter demand heater is a Paloma. They are no longer made but are available used. I was going to buy one, but ebay people kept bidding them higher than my new Aquastar. Besides parts are available for the Aquastar unlike the Paloma.
My shower curtain is a conduit loop that I connect to my overhead rack shown in other photos above. You can buy a freestanding shower enclosure instead though. You put it up sorta like a tent. I believe Coleman has them.
Other hot shower options are the Zodi and the new llittle coleman thing. Really don't know how well these work.
Anyway, if you see me camping anywhere, just come ask and I'll let you take a shower since you're not a stranger.
Old 07-06-2003, 04:46 PM   #33
Thanks for the reply. Your trailer has a lot of great things going on. All very sensible. One things for sure if I see you camping I'll know it's you.
Old 07-09-2003, 08:38 PM   #34
Solar finally
I know, it's not enough solar to really run anything, but it was better to put them up than have them sit in a dark corner doing nothing.
Together the three pannels rate an amp and a half, but I'll probably only get a third of that due to their lying horizontally. But that will keep battery topped off during disuse.
Greatest challenge was to fish the wire through the conduit rack and down to the battery.. AND back out. (the hard part)
I may put an old quarter amp 12v computer fan in my roof vent and I should be able to run it indeffinately. Till the battery dies.<img src=http://www.fiberglassrv.com/board/uploads/3f0cd17477ab4solar2.jpg/>
Old 07-09-2003, 11:19 PM   #35
Renovations
Tom;
An absolutely wonderful project and example of patience and skills. My wife and I love your paint job and all the neat mod you have done. We are very interested in one of the demand water heaters you installed. I read all the threads and finally found out the brand and model. Great work and you will love the egg.
Brian and Pat
Trillium 5500 and 1300
Land of the midnight sun, Edmonton
Old 07-10-2003, 12:30 AM   #36
It has been fun
Golly, gee Brian,
Thanks for the compliments
You know, none of the demand water heaters are officially approved for RV use. If you do it, make sure you do an extra bang-up good job. Over design everything about it and even if it isn't officially approvable, you'll know it's done safely and right.
I just hope I did it as well as you are going to
Old 08-07-2003, 11:42 AM   #37
Roof vent too
The crank that came with my new roof vent / window thingie kept catching tall friends right on the soft spot on tops of heads.
It would have been preferable if they put that soft spot on the back of heads, but they don't listen to me.
So intead I put a propane knob on it. Much lower profile (Higher profile??) and just misses that poorly placed soft spot.
Old 08-11-2003, 03:25 PM   #38
final details
Well, probably not FINAL details, but here are some more silly little things.
1 as mentioned before, here is a propane knob in action. Note that you can't really jam your back or head on it? See photo in below post... sorry
Also note that the curtains snap down and tight to frame with snaps to hold in place and block out all light. All Light? All light, and heat. the following picture shows the four layer insulation on the outside of the curtains. The outer layer is really nice fabric with sewn seams that hold the layer of space blanket mylar, vapor barrier, and cotton batting all together. Drops the temp of Skimp in full sun greatly. Allows me to sleep in if I wish. Also holds heat in and out.
<img src=http://www.fiberglassrv.com/board/uploads/3f380837ecd27curtainliner.jpg/>
I even put a snap on curtain on the door window. I had to reline the door with new naugahide (picked grey because on sale and hides my dirty finger tips. Mounted a botle opener under window. That way you don't have to rummage inside if you need it. access from inside or outside. Good place too because if the bottle was shaken all suds will just run down the door and outside whether door is open or not.
<img src=http://www.fiberglassrv.com/board/uploads/3f38090ca876ddoorliner.jpg/>
Speeking of door... has hit me in butt too many times swinging in the wind. I made a pvc tube with a bungie cord stretched inside. It mounts permanantly to my conduit frame and can then be used to grab doorknob and hold in position. Can give a bit in big gust of wind so is not totally rigid.
<img src=http://www.fiberglassrv.com/board/uploads/3f3809b838289doorpost.jpg/>
Old 08-11-2003, 03:37 PM   #39
didn't want to overload a post
:wave
Continuing above....
I found that my rolling greywater container (blue plastic thingie) can be held in place during transit by putting table leg through handle...
Hate it when things roll around.
The closet of Lainey's is superior, but I had already done mine by then. It is thin birtch plywood on adjustable rails rivetted to cabinet walls inside. Adjustable..
All homes must have art. Right?
I found a little antique painting in an oval frame that fit between doors of upper cabinet.
<img src=http://www.fiberglassrv.com/board/uploads/3f380b0109c56art.jpg/>
The same space on the forward cabinet has an antique match holder. Strike plates are along side of basket. Had to stuff a piece of foam down with matches to hold them in place during transit.
To the outside again.
I painted the chimney in the place where the former stove vent came out.
<img src=http://www.fiberglassrv.com/board/uploads/3f380b9ccaa42chimney.jpg/> I had to cut the belly band because it was the perfect place to have my hot water heater flue come out. Flue is caulked with twenty dollar fireproof caulk and flashings. Cover prevents cooties from entering while not in use.
The other screened vent has a computer fan in it to duct out hot air that could possibly build up around water heater there under the galley. It also provides positive air supply to the heater through the lower vent shown below
<img src=http://www.fiberglassrv.com/board/uploads/3f380c4c7ef54ventcover.jpg/>
I put a magnetic stripped piece of clear plastic that serves as a dust cover when in transit. It holds on tight!
Old 08-11-2003, 03:45 PM   #40
Sorry
<img src=http://www.fiberglassrv.com/board/uploads/3f381dfc41ec2proknob.jpg/>
scamp
Lots of Scamp modifications Thomas Haney Modifications, Alterations and Updates 74 06-07-2019 08:33 PM
Scamp 16' Modifications Legacy Posts Modifications, Alterations and Updates 23 06-10-2015 03:01 PM
New Owner.... 85 13 ft. Scamp... needs lots of work Joe Steadman Care and Feeding of Molded Fiberglass Trailers 41 03-27-2012 08:50 PM
13' Scamp Work in Progress (Lots of Additions) David Morgan Modifications, Alterations and Updates 41 06-04-2010 03:44 PM
Our modifications to the Scamp ted saxton Modifications, Alterations and Updates 9 02-19-2008 06:30 PM
